Just Fresh Air
Discussion in 'Gen 3 Prius Main Forum' started by Metalman, Sep 18, 2012.
  1. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    We seldom use the Prius unless the AC is running. However, today it was not hot enough for the AC and we wanted to run the fan and keep the windows closed to reduce the wind noise. I can't figure out how to run the fan without having the set temperature display. I presume when the temp is displayed, the control will determine whether heat or AC will be activated. I want to run the fan without either AC or heat. Is that possible:?
  2. 50324prius
    50324prius Junior Member
    39
    iowa
    If it is the "auto" mode push the "AC" button to turn the compressor off. If you do not want heat, set the temp down to "LO" and then adjust the fan accordingly. Also, make sure you have it set for outside air.
  3. El Dobro
    El Dobro A Member
    7,088
    3,270
    You don't need Auto either, just use the fan speed buttons.
  4. Metalman
    Metalman Member
    107
    17
    When I push the "auto" button to turn off the AC, the fan also shuts off. When I turn the fan on, the "auto" turns on. I can get the fan to run without the temperature showing on the display and the auto light lit. So I presume I'm either getting heat or AC.
  5. bisco
    52,286
    if you press 'off', then hit fan for one bar, everything comes back on. turn temp all the way down, press a/c so lite goes off and you're getting fresh air, no heat, no a/c. you should also be able to press 'auto' so lite goes off, but if not, you're still not getting a/c if a/c lite is off.
