What if?
Discussion in 'Gen 3 Prius Main Forum' started by scooter4n, Sep 19, 2012.
  1. scooter4n
    scooter4n Junior Member
    27
    27
    Question is:
    What happens if I hit Parking button when driving on the freeway or the road?
    What happens if I hit Reverce shift driving on the freeway going forward?
    I have 2012 prius, and I keep my arms away from that shifter, because I am afraid of that happening.
    anyone knows?
  2. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    In both P and R, if you are going above about 3 MPH, you shift to N.
    Under 3 MPH, P clunks badly and stops the car, and R pretty seamlessly becomes D
    In the wildly unlikely scenario that you have Unintended Acceleration in a Prius, shifting to P or R is a quick way to quit accelerating. (I was a passenger in a Ford Windstar that suffered Unintended Acceleration, so it DOES happen. The hood kept popping open, so the owner tied the hood to the throttle cable, when the hood popped open again, we could not see but were going faster and faster!)
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    With the 2010 Prius for both instances the only thing that happens is that it shifts in to neutral. Toyota is watching out for you. Try it for yourself so you will know. I would think the same would hold true for the 2012.
    The only thing to watch out for is do not shift in to park when you are going below about 5 mph. It will go in to park with a very sudden jolt as the parking pawl engages !
  4. scooter4n
    27
    27
    thats why I was asking. I was rolling slow on the driveway and pressed the P, well you know what happened. pretty hard stop.
    Thanks all, I was pretty sure that toyota has this fiturtes in mind, but was just making sure, you never know...
    thanks all
  5. Munpot42
    Munpot42 Senior Member
    1,391
    544
    Santa Monica, Ca. 90405
    I wouldn't try it myself, just believe them, it is true!
  6. jdcollins5
    5,131
    1,346
    Wilmington, NC
    Come on ! Have some faith :) If you will search on here there was an earlier thread on this subject where several people tried this and it was recommended that everyone try it for themselves so in an emergency they would know exactly how the vehicle will respond.
  7. jenzfc
    jenzfc Junior Member
    San Francisco Bay Area
    Whoa, I'm also always been afraid of pressing P by accident while I'm driving. Good questions!
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    It works just as JD says it does. :) I've tested these emergency shutdown features at 100mph!
    WE0H and jdcollins5 like this.
  9. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Is that your way to get 61MPG at 100MPH?
  10. F8L
    19,011
    4,083
    Grass Valley, CA.
    I've got all kinds of tricks! :p
