Entune questions - Iphone Connection etc.
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by benalexe, Sep 25, 2012.
  1. benalexe
    benalexe Member
    198
    30
    Commack, New York
    So I was trying to set up entune in my 2012 prius plug in basic model and I was having problems connecting to the interne. I have an Iphone 4s. I called the toyota hotline and they told me I must connect with the USB cord and I can't connect to the internet via bluetooth.
    I was surprised at this but the guy did not seem to know what he was talking about. Can anyone confirm?
    Secondly- There are menus in the entune for messages and calendar and they are greyed out. Any idea why this is? Can I get text messages or email on my entune?
  2. mcmoyer
    mcmoyer Junior Member
    71
    Fort Worth, TX
    Fairly certain that I can't connect to the internet via bluetooth. I think I tried it once and could never get it to work. Also, with my 4s, bluetooth runs the battery down so quickly I never thought it would be a good idea anyway ;)
    The greyed out options don't work with iOS. I think the calendar works with Android, but I don't think the text messages work with anyone at this point.
  3. benalexe
    benalexe Member
    198
    30
    Commack, New York
    Thanks.. One more quick question. Is there a way that when i connect it to the wire the iphone can automatically connect to the internet instead of entune always asking?
  4. mcmoyer
    71
    Fort Worth, TX
    I wish there was! It's a pain to have to confirm every time. Maybe somebody else knows how to do it. Plus, half the time I have to restart the entune app on my iphone.
  5. GerryL
    GerryL Master Model Railroader
    170
    Minneapolis, MN
    Just the opposite. I got the text messages to work ONCE with my Galaxy S II. But the calendar doesn't work at all.
  6. benalexe
    benalexe Member
    198
    30
    Commack, New York
    Just realized I am missing some apps on my entune. I called Toyota and they are sending me a memory stick to update the system. If your are missing the apps call Toyota.. I think the new pip's do not have the update.
  7. dk_brookdale
    dk_brookdale Junior Member
    64
    Since upgrading my iPhone4s ti IOS6 Entune crashes every time I start it up on the iPhone. This is a Toyota issue - they need to update their app. I called Toyota about that but they had no idea.
  8. benalexe
    benalexe Member
    198
    30
    Commack, New York
    So Far Entune is not as bad as I thought it would be. But I did try Pandora today and it sounded horrible. Very flat and tiney I think it may be because it is streaming at a lower bit rate. The regular radio sounds fine in the car.
  9. Vinoh
    Vinoh Junior Member
    San Jose, CA
    Delete and reinstall the app.
  10. MBRGuru
    MBRGuru Member
    255
    26
    Do you have the DA? Are you running software 2.1? That fixed the poor sounding Pandora.
  11. mcmoyer
    71
    Fort Worth, TX
    This is a setting to stream at a higher bit rate. Click the options button to get to it.
  12. benalexe
    benalexe Member
    198
    30
    Commack, New York
    MBRGuru What is the DA? And the softwaere do you mean Pandora or the Entune software?.
    mcmoyer The options on the head unit?
  13. mcmoyer
    71
    Fort Worth, TX
    options on the head unit once you start the Pandora app
  14. benalexe
    benalexe Member
    198
    30
    Commack, New York
    So that was better but it would play half a song and then pause etc.... Oh well.
  15. MBRGuru
    MBRGuru Member
    255
    26
    There are two radios available, the Display Audio and HDD Premium. If you've got the Display Audio, just make sure you have v2.1.0 software installed. As mcmoyer said, there's also that higher quality setting in the app, but if you're in a weaker signal area then you'll experience that buffering / pausing.
  16. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Can confirm that you CAN connect via Bluetooth to Prius 6" display. You do need to get the Hotspot service from ATT or your provider and put the Entunes PWD and ID into the Prius display settings.
    Toyota will tell you this is not possible.
    Works great.
  17. dk_brookdale
    64
    Yes, that was it. Now Entune does not crash.
  18. benalexe
    benalexe Member
    198
    30
    Commack, New York
    Strange..I was just in my car and got a call on my cell. For some reason the bluetooth did not sync. So I Stopeed the car and went into the settings menu where i clicked on connect to my iphone. Then for some reason the bluetooth was playing my music without being connected to USB. Something I was told can't work with the 6" radio. Weird.
  19. Quentin
    Quentin Member
    335
    West Virginia
    Bluetooth audio streaming or Entune via Bluetooth (pandora, I heart radio)?
    Bluetooth audio streaming from your phone's music app 100% works. You can run Pandora (the ios app) or YouTube on the phone and it will stream via Bluetooth. The actual Entune app still supposedly requires a USB connection.
  20. ProximalSuns
    1,877
    PNW
    Not on the 6" nav system. No USB connection required for any Entune's function on the car.
