Just got my 3rd Prius.. a Plug in.. here is my review
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by forte88, Oct 2, 2012.
  1. forte88
    forte88 Member
    143
    44
    Socal
    Obviously I'm a Prius fan.. this is my third one. 1st one was a 2004 series 3 (i think) with no Nav. Pretty basic but had its 3 door smart key entry which I found pretty sweet. I sold it to a friend that now has nearly 200k on it.. and it's STILL on it's original brakes!! Other than routine maintenance such as tires and a headlight and tail light or two... still going. And Still has the Prius Chat Hybrid decals along the doors :) My second one was a 2010 Prius III with the NAV and driver door only smart key. I sure did miss that hatch not opening for me... But the car was as dependable as the first. LOVED the nav system.. Saved me lots of times.
    So onto my review of my new Plug-in.. Standard. (not advanced). I've only owned it a few days now but I think I'm ready to start with some reviews. Lets start with the bad: The NAV system!! Smaller screen.. I think I could deal with that.. but first thing I noticed was my missing POI's and the ability to add POI's by voice command. I loved the single button push to "Go Home" on my 2010. Now you have to press a few buttons to push to go home. Not even a voice command to "Go Home"? C'mon!!! On the 2010 I could go directly to the Map Screen with a press of the "Map" button.. Now you either fumble through the menu while your driving.. or have to give a voice command to "Show Map" which is bothersome if you are listening to some cool tunes. The POI's are basically from the phone now and will not work if you are not in cell service area.. ouch. I no longer have the ability to say.. find Steakhouses or BBQ. And I don't see food categories such as BBQ, or Chinese food as in my old NAV. I also do not see the traffic information on my route. Unless I'm just missing how to do it.. does this info no longer use XM satellite and uses Bing? Ugh.. It seems a lot on the NAV requires several button pushes to navigate around now. Not good.. and frankly.. a bit dangerous. Now I do like the fact that I can give a voice command of a full address now in one shot. That is an improvement over the old NAV. The pop up screens with lanes suggestions are nice too. So it's not all bad with the new nav.. but I like my old one better so far. My Radio presets are limited to only numbers. No longer naming of the station? I only see the station name if I tune to the station now. I had several pages of presets before.. now only 1? For all the satellite and AM/FM bands? The weather is cool. Fuel prices are cool.. but again.. totally dependent on my phone.. and it seems like it's kinda slow. I'm still on 3g network tho. I know the larger screen is available on the Advanced version.. and probably does all the stuff I used to like on my 2010.. just not worth the extra $$$. I really don't need leather or radar assist. Ok. worst of all.. The Toyota Entune app for my car doesn't include Charging stations? Wth!!??
    So on with the good. My commute is 20 miles one way. My first day to work on a fresh charge my summary of mileage was 101 mpg when I arrived at work. Wooohoo.. My commute has 10 miles city, 10 miles hwy. Mostly flat driving. I work for a college.. but no charging stations installed. It's going to be a chore to convince administration to install charging stations. It's been brought up in the past but has fallen on deaf ears. Especially in this environment of gutting education funding to the core. I'm busy trying to find some way to get them installed with a subsidy of some sort.
    I'm still yet to go through my 1st complimentary tank of gas and I have gone nearly 300 miles so far. Still have over a half a tank. I'm a happy camper in that regard. The car handles just like it's predecessors. I'm not finding any differences except I'm finding it easier to win on the gas saving video game on the dash display. I'm sure my mileage performance will improve when I can turn down the A/C. We are currently having a heat wave here in Southern California.
    The interior is very similar to my 2010. The front seat center arm rest no longer has the sliding to and fro option. I don't think I'll miss that. I never used it much. But I am going to miss the ability to remove the cup holders to clean. Why did they get rid of that? oh and I got my 3 door smart key entry back.. Hallelujah!
    I noticed that they rotated things on the steering wheel thumb buttons. I never really got used to the ones on the 2010. It seemed it was more logical on my 2004 too. But these seem pretty logical to me.. and I think I'll prefer this order better than my 2010 model.
    Charging seems simple enough. I did plug into a 15 amp circuit at my brother in laws house outside and for some reason.. it tripped his circuit breaker after a few minutes. It also tripped one at my home later that evening. I'm not sure if something else was on concurrently on that circuit.. but I have now switched to one that I know is all by itself with nothing else running on the circuit.. but it is currently requiring me to use an extension cord.. (I have a nice thick gauge chord and I felt it for heat).. It seems to be just fine. I know the manual says not to use an extension cord. But until I get the electrician out to my house.. I'll have no choice. I should have it's own socket in the driveway in the car port in about a week. I started to also to use the timer now and have it charged up in the very early morning hours so it's done about an hour before I go to work.
    I'm not noticing any decrease in performance with this heavier Prius. The suspension does seem a little more stiff. Maybe it's just new, and my fat butt hasn't broken in the springs yet. I haven't tried the speed bump brake skip trick yet. I'm curious to see if they still do that. Both my 2004 and 2010 would skip for a split second at a certain speed going over a speed bump.. even after the firmware upgrade.
    Well, that's about all I can say with my few days into it. I'll add as I go on. I'm not crazy about the new NAV.. but I am still pretty happy especially with the incentives, rebates, and interest rate, and most importantly.. my MPG.
    ewxlt66 likes this.
  2. benalexe
    benalexe Member
    198
    30
    Commack, New York
    I hate the arm rest. My elbow rests right in the cup holder.
    lensovet likes this.
  3. bisco
    52,386
    i have 6 pages of presets, with station name on each one. 3 are xm tho.
  4. forte88
    forte88 Member
    143
    44
    Socal
    I'll have to look again. Do you have the 7 inch screen?
  5. bisco
    52,386
    no, the base. when i say names, i mean numbers. there are 6 pages and you can cycle thru them on the steering wheel mode button or use the arrows on the display.
  6. forte88
    forte88 Member
    143
    44
    Socal
    Yeah.. for instance.. I listen to Deep Tracks on XM alot. It shows up only as 27.. until I tune to it.. then I get the name of the station. I'll have to look again to see where I'm missing the pages. I have about 14 or 15 favorite stations. Now I have to memorize which each number is.
  7. bisco
    52,386
    right, sorry.
  8. raimix
    raimix Member
    204
    33
    Long Island NY
    Agree, navigation needs improvement maybe even hearing aid. I have to repeat many times to get destination done right. Rather pull over put on park input address.
    You can actually preset up to 36 radio stations. Just click on the arrows to flip through pages when you are at the radio screen.
  9. forte88
    forte88 Member
    143
    44
    Socal
    Thanks.. good to know on the pages of radio stations. I must have just missed it somehow. I'll look tonight.
  10. Chris_SoCal
    Chris_SoCal Junior Member
    44
    Wildomar, CA
    Welcome aboard!
    This car really grows on you. I really like the PIP and so does everyone that rides in it.
    Charging at Work
    For now maybe you can ask your employer if you can park near a compressor/machinery area, or near a maintenance shed etc... These areas usually have a 110V plug available somewhere. Relate to them that the electric usage would only be about 50 to 75 cents at peak usage time for a full recharge. They may make you sign some sort of liability waiver etc..., but I could imagine that a college like the large company I work for would be into the "Green/ECO" aspect of it.
    Seeing that you are in my area somewhere: LA/OC/IE/ SD, all of the utilities like SCE & SDG&E are on the rebate and incentives bandwagon. You can help your employer out by putting together the information and web links for them so they have easy access to this information. I can even zip all the links and PDF's I gathered a couple months ago to present to my employer if you need them. If you show them it is a win/win for both you and them, they may be willing to help you out.
    I parked next to the Air Compressor pad (with permission) and used the 110V there for about 2 months until they set up 2 dedicated parking spots with 110V drops.
    Good Luck!
    usnavystgc likes this.
  11. forte88
    forte88 Member
    143
    44
    Socal
    Thanks. I'll take you up on the offer for the PDF's. Message me and I'll give you an e-mail address to send it to. Or maybe even a FTP site if needed. I've called the Calif Dept of Energy and they gave me a few leads. I also e-mailed and spoke with someone at Chargepointamerica.com. They apparently had some American Reinvestment Act funds for charging stations as an infrastructure stimulus. They were even giving free ones to just consumers at homes. But apparently that money has run out because now everyone is wait listed. They advised to contact one of their vendors to see if they have any funds left. Being a community college, I thought it would be good PR for both the college and Chargepointamerica: Green jobs, environment.. saving fuel... and so on.
  12. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    Nice write up. Can you recharge running on gas and then run another 11 miles on EV durring long trip? How much heavier is the PIP?
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    nope, not possible as stated in other threads
  14. CraigCSJ
    CraigCSJ Active Member
    287
    144
    San Bernardino, CA
    On my base Plugin, I entered an address for Home in the "My Destinations" area. When wanting to go home, I press the talk button, say "Favorite Home" and Nav repeats Home and asks if I want to to there and I say yes. I find the voice system using "Fovorite" and a name for an address I already inserted into "My Destinations" works very well.
    I also find that the voice "Find next" works quite well with category names, such as "Find next Subway"
  15. forte88
    forte88 Member
    143
    44
    Socal
    Thanks, I'll have to do it that way. I did like on the old NAV that pressing "home" was very simple. The voice command "Favorite Home" willl work tho. Appreciate the advice. I'm still learning this thing.
    Next I have to figure out why my Android phone won't do the texting and e-mail. Says it's not supported.
  16. nickfromny
    309
    24
    Binghamton, NY
    Salesman said on long trips that I could get another 11 EV miles after the ICE recharged batteries. Can you point me towards the other threads?
    Thanks,
  17. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    Nick, your salesman is clueless.
  18. 13Plug
    581
    105
    2013 Prius Plug-in
  19. CharlesH
    2,797
    1,165
    Roseville, CA
    The only time the ICE will add to EV miles is indirectly if you go up a long incline (using the ICE) and recover the energy via regeneration on the way down. Given a long and steep enough run, the EV battery can be completely recharged. But the ICE will not recharge the EV battery in ordinary "flat" situations. There would be no point incurring the losses in the charging system, just to get "EV" miles. The control system in the Plug-in is tuned to use the ICE or the battery in the most optimal way, not to maximize EV miles.
    As Swanny said, clueless.
  20. miscrms
    miscrms Plug Envious Member
    2,079
    527
    Phoenix, AZ
    FWIW this would more or less defeat the purpose of a plug-in hybrid. The whole point is that charging the battery off the grid (generally) uses less fuel, creates less pollution, and costs less than charging the battery from the ICE. To get the maximum benefit, you always want to arrive at your destination with an empty battery so you can accept as much charge as possible to offset as much gasoline use as possible.
    Beyond that, using the ICE to charge the battery and then the battery to drive the wheels through the electric motor is less efficient (generally) than just using the ICE to drive the wheels directly. This is why the standard Prius generally tries to just keep the battery level constant rather than cycling it up and down. The only time the Prius tries to use the battery is under specific circumstances when the increase in overall efficiency can overcome the loses associated with charging and discharging the battery. Cruising at a slowish speed is a good example. When lightly loaded an ICE is particularly inefficient. By loading the engine with the generator ICE efficiency can be increased. Once the battery builds up sufficient charge the engine can be shut off and that charge used to power the car for a while. This results in less overall fuel usage, as the energy lost charging and discharging the battery is less than the energy that would have been lost running the ICE continuously at low efficiency.
    In a standard hybrid the battery/electric drive is basically there to compensate for inefficient driving. The more efficiently you drive, the less the battery/electric motors get used. In a PHEV its almost the opposite. The goal is to use as much power out of the battery as possible in order to offset as much gasoline with grid electricity as possible. Once the battery is depleted of its grid charge, the most efficient way of operating is basically the same as a standard hybrid.
    Rob
    usnavystgc, DadofHedgehog and jaymac like this.
