iphone 5
Discussion in 'Prius c Audio and Electronics' started by Revan86, Sep 12, 2012.
  1. Surrylic
    Surrylic Junior Member
    122
    Winchester VA
    I'll update tomorrow see about using it through USB... But I know Siri always woks for me via BT. I mean, I have to hold the Home button down still, but it uses the car speakers just fine.
    I'll do more Pandora-Ing tomorrow to update a bit. The little I've done has worked fine, and when I plug it into USB it always plays music through the car speakers like normal, so far it hasn't used car speakers.
  2. MBRGuru
    MBRGuru Member
    255
    26
    Siri works through Bluetooth. Just pair the phone and press and hold the usual button on the phone. The system looks like it goes into a phone call, but it should work. Obviously, not ideal since you still need to use the hone to initiate it.
  3. Revan86
    Revan86 Animal nerd and alt car guy
    286
    84
    All over northern IL
    I just want to push the talk button on the wheel and say " Siri find me a liquor store" then Siri using the entune display shows he the nearests one and Siri tells me theses are the closests ones to you. And ask me if I want directions lol
  4. DKTVAV
    DKTVAV Active Member
    510
    101
    I just got the iphone 5 today:)
    I haven't set up Entune yet since June after reading all horrible posts about it. And still didn't receive the flash drive from Toyota yet, should I set up Entune before or after update?
  5. Kmullin80
    Kmullin80 Junior Member
    48
    New Jersey
    Have you used it plugged into the USB as well?? I have a c 2 and I want to upgrade to the 5 but I plug in the phone most of the time to USB and want to makesure I can use it that way also.
    iPhone ?
  6. RJphxC
    RJphxC New Member
    22
    Glendale, Arizona
    Using USB Siri goes through the phone not the sound/speaker system.
  7. crebble
    crebble Member
    176
    47
    Shohola PA
    You still have to hit the home button on the phone. No other way to do it. I wish Apple would release some kind of remote button to activate Siri without fumbling with the phone. It works pretty well through BT audio. I wouldn't trust the iOS 6 maps as your sole GPS, though! Today it couldn't find my work address and routed me completely the wrong way.
  8. jsfabb
    jsfabb Active Member
    617
    156
    Medford, NY
    If you want a good GPS app, use Waze. It uses crowd sourcing to update your route as far as traffic, accidents, police activity, etc. Beware though, it uses a lot of battery power, so make sure you are plugged in. Also, if you want to hear the verbal directions/warnings, make sure your audio is set to iPod.
  9. Lionsfan
    Lionsfan Junior Member
    26
    Montrose, MI
    2015 Prius c
    I have a 4S and it recognized it right away but I have no folder control when I'm using BT. Only if I'm plugged into the USB cable and use it as an ipod and not BT. But then when I'm using it as Ipod I cant play the audio...just cue it up through the folders. I have to switch back to BT to play it. Not a deal breaker but it should be more fluid than that. too many steps for a "hands free" device.
  10. jsfabb
    617
    156
    Medford, NY
    I have a 4s also and do have control through the audio screen in the car. Sometimes it can't find the iPod source and just keeps hunting. When that happens I just start the Entune app again on the phone. That usually works. If it doesn't, try rebooting your phone.
  11. DKTVAV
    510
    101
    Do I need to set up my iphone 5 I just received now and update the Entune later?
  12. Luisaophie
    Luisaophie New Member
    You can still get it without paying early termination fee. You can add a line to your existing service for 9.99 per month and get the phone on that line. Then transfer it to your current line. our "new" dummy line will not need a data plan.
    Bigg Boss 6
  13. DKTVAV
    510
    101
    Are you replying to my post? I don't really understand what you're trying to say.
  14. MandyTee
    MandyTee 2012 Prius Three ~ Classic Silver Metallic
    49
    Greater ChicagoLand, IL
    I had an old....3G iphone...not even the "S" :) and I just got my iPhone 5 this Monday. What a world of difference. Everything works fine in my GenIII Prius with Entunes/Bluetooth/USB cable. The same ol' snafus I see complained about are still present, but for the most part it works well. I can't believe how great the iPhone 5 is compared to the 3g.
    I also know there are a lot of complaints out there right now about Apple maps - but I have to tell you, Apple Maps is way better than the map app in Entune. You can look at a list of all the streets/directions and not just have to blindly trust the map (I like to have a general idea of where the route guidance is taking me - sometimes I want to avoid toll roads, or areas where I know traffic will be bad, or construction will slow me down). The Entune map is outdated in my area, missing streets, and has taken me wrong directions several times. Since I bought the car I've still been using my TomTom because the maps in Entune suck. I'm happy to say my TomTom is retiring and I'll primarily use Apple Map. Love the fact that when connected via bluetooth the directions come right out the car speakers, and then when I get a phone call, the directions are muted. I absolutely could NOT STAND that the voice guidance did not mute when a phone call came in using the included Entune map and bluetooth. When I would bluetooth connect my TomTom to the car, it would mute the directions when I got a call, too.
    I honestly don't see much point in Entune, really. Seems like I can do everything I need via Bluetooth, so I sure won't be paying for Entune when the free 3 years are up.
    I also noticed streaming Pandora through Entune sounds like crap. I streamed Pandora via bluetooth from my phone, and guess what? Sounds 110% better.
  15. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I'll never buy an iphone cos I don't like the companies attitude; Apple stink imho.
  16. Revan86
    286
    84
    Wow that's cool. NOT. Why would you bother posting in this thread unless your trying to start crap. Any one reading or posting in this thread does not want to hear your hate mongering or trouble making.
    Happy driving and may the mpgs be with you and all that, now power mode off.
  17. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    Thank you for your comment.
    I noticed earlier in the thread that many posts were singing the praises for the iphone, so I thought that I'd add balance and my view. It appears you made no comment to the positive iphone posts, yet felt the need to respond to my negative experiences.
    That tells me alot about users of that over priced, bug ridden piece of tat. :p
    Tat (consumer item classification) - Wikipedia, the free encyclopedia
  18. FastZX6R
    FastZX6R Junior Member
    Well I've tried time and time again and on my Prius C2 the iPhone 5 sound is routed through the speakers on phone calls, but the turn by turn directions are muted when the phone is paired up to my regular Prius C2 stereo system. So no voice turn by turn directions when my iPhone 5 is paired up to my standard stereo system.
    Am I doing something wrong?
  19. MBRGuru
    MBRGuru Member
    255
    26
    You have to be listening to either iPod or Bluetooth Audio to hear the turn-by-turn directions. They're mixed into those streams by Apple, so if you're not listening to one of them you won't hear your directions. You could change the path on the phone to output from them from the phone speakers, but that might not be loud/clear enough.
  20. FastZX6R
    Interesting I'll try that
