440 MILES FROM START - only 44 MPG - SHOULD I BE WORRIED?
Discussion in 'Prius c Fuel Economy' started by felixm0510, Oct 7, 2012.
  1. felixm0510
    felixm0510 New Member
    I
    Hi everyone, great forum. happy to be here.
    Just got a beautiful metallic blue streak on Monday. Already drove 440 MILES from date of purchase.
    I have been driving like a GRANDMA.
    I have ECO mode in DEFAULT.
    I drive at EV speeds when I can.
    I drove on the freeway 30% of the time and roads 70% of the time.
    Yes, it only shows 44 MPG , for the 440 miles from the start.
    Now, when I do PER TRIP (A or B) , it shows about 46 MPG
    The question is: SHOULD I BE WORRIED?
  2. PriusCamper
    PriusCamper Senior Member
    12,956
    5,266
    Pacific Northwest, USA
    It takes a while... For both learning pulse and glide and for car tires to wear in... also higher psi in tires = higher mpg! High mpg is not something you simply buy, u have to learn all the details, develop skills, make mods....
  3. Ashley7
    Ashley7 Active Member
    545
    222
    Oregon
    2019 Prius
    Sounds totally normal for a first tank.
  4. F8L
    19,011
    4,083
    Grass Valley, CA.
    Stop driving like a grandma and just drive the car. Don't drive aggressively, just drive. See where your mpg goes from there. Some people actually reduce their mpg by driving too conservatively. High freeway speeds will always hurt mpg though. So keep your max highway speed at or below the posted limit. 60mph or less is best.
    Short trips of less than 5miles will also really reduce overall mpg.
    born_again, Tracy and frugaldriver like this.
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    Ohh and a lot of areas have transitioned to winter blend fuel and temps are dropping. Once temps (during driving times) drop below 60F mpg will start to suffer. Expect to lose 6mpg+ in winter.
  6. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    EV mode is great for parking lots, not for real driving.
  7. DKTVAV
    DKTVAV Active Member
    510
    101
    Don't worry, I got similar result on my first tank: 425 miles. But now I'm having 500 or more in a tank, you will get there soon enough after learning all the tricks in this forum.
  8. frugaldriver
    frugaldriver Ceterum censeo Carthaginem delendam esse - Cato
    81
    26
    Somewhere over the rainbow
    Completely agree with this post. Just don't drive aggressively and you will probably do fine (and have less stress, not that all Prius drivers practice zen on their daily commutes , but it does help to be calm). Also as I have suggested before in other posts, if it is less then 4 miles (or maybe even 5), consider riding a bike if you can. Much more enjoyable and better for you and your car.
    (NOTE: I am by no means an environmentalist, I just figure everyone could stand to get some exercise every now and then, especially when 1/3rd of Americans are obese)
  9. felixm0510
    I
    Thanks for the replies.
    Well, I took it off ECO mode and now it is getting 39 MPG
    Now when they say 46 highway and 53 roads ... is this the minimum ?
    Or it is possibly to average 35 highway and 42 roads, as I did the last 2 days.
  10. F8L
    19,011
    4,083
    Grass Valley, CA.
    It all depends on how fast you drive, environmental conditions and your technique. If those are not exactly as there are when official testing for EPA mpg is determined then you will have different results or as they say YMMV (your mileage may vary).
    I honestly don't know how you could average 35mpg on any long highway trip unless you are driving at 90mph with flat tires.
    Tracy likes this.
  11. winnertakesteve
    154
    47
    Toronto ON
    2025 Prius Plug-in
    SE
    I think the "c" should stand for country rather than city. In stop and go city traffic I'm often in the low 40s for mpg, and likewise on fast highways. But on a country road between 60-80km/h, I get 60mpg.
    Tracy likes this.
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    No. Read Car and Driver: The Truth About EPA City / Highway MPG Estimates | PriusChat to learn more about the EPA tests.
    If you want more data points, these are CR's test results:
    The most fuel-efficient cars
    Best & worst fuel economy
    Last page of http://www.consumersunion.org/Oct_CR_Fuel_Economy.pdf describes their tests vs. the old (pre-model year 08) EPA tests.
  13. Red_c
    Red_c New Member
    I just got my Prius c a few weeks ago and I have been pleasantly surprised with the mileage so far.
    I reset trip A on every tank. First tank the car said I got 57.1mpg (actual fill up was 54.9). The second tank read 58.8 (actual was 56.7).
    I just returned my 2010 Prius from lease and the mileage was never as high as it is on this car, I was averaging about 52.5 for the last 7000 miles that I had the car.
    It does take a while to get the hang of how you can get the best mileage.
  14. Mendel Leisk
    41,785
    We used ECO for the first 6 mo or so with our reg 3rd gen Prius, then switched it off (went back to "normal" mode), and the mileage didn't change one iota. The main change was a more responsive gas pedal. I found the pedal response in ECO way too sluggish; I think it's actually hard on your gas foot, having to constantly move the pedal through more travel.
    Are you still on your first tank? With the various factors that might have happened at the dealership, I wouldn't trust the displayed mileage as being represenative of the future. It could have just sat idling for extended periods, for example. And after fill up, I still wouldn't trust it, verify with calculation (though the in-dash display is supposedly getting closer).
    There's many things you can be doing to improve mileage. The car is capable of electric only propulsion off-and-on during lower speed driving. It will do it unbid, and you can help it into that mode. The owners manual for your C likely suggests:
    Lift off the gas pedal, then gently re-apply, keeping HSI bar display to left of centre mark
    This will usually put the car into electric-mode, at least if it's warmed up. If you do this often enough you will eat up the charge though, so do this in moderation. If you see the charge dropping fast you can switch to pulse-and-glide: give enough "gas" to kick on the engine, accelerate a bit over your target speed, then coast (engine should shut down again), maybe feathering the "gas" to get a small electrical boost to your glide.
    Also, just drive conservatively: abide by speed limits, leave decent following distance, coast up to stops. Whenever possible start your drive with plenty of time. Avoid jumping lanes. Do what you can to minimize braking; this by itself makes for more efficient driving.
    Then, to reduce your overall consumption: consolidate trips, consider alternatives, reduce "optional" long drives, etcetera.
  15. Tracy
    Tracy Member
    171
    101
    I got 55-63 my first few tanks - but I had a week off and did a lot of driving out on 2 lane (highway) roads which I swear is the sweet spot for this car (at least for me) - better than the city, better than the freeway. Something seems off whether it's tires that need more air or you are gunning it or running right up on stoplights and doing hard braking. I sometimes find myself struggling (like last week - when our temps first dropped) to break 50 mpg and then....when I just stop TRYING...boom! I was back up to 55. So, the points of others here about "just driving" it totally make sense.
    winnertakesteve likes this.
  16. ngc4565
    ngc4565 Member
    193
    33
    Pennsylvania
    2023 Prius
    Personally I do not think that you should be worried at all. I recall having your feelings after our first tank on a 2010 model IV. That tank came in at about 42 MPG, and I thought that we had been had. By the time we reached the third full tank of gas, the mileage was running north of 50 MPG and it has never gone below there since. Please consider setting your tire pressures to a level consistent with the recommendations here on PriusChat. I am not familiar with what those are for the "c" but do believe that they make a small difference.
    Tracy likes this.
  17. felixm0510
    I
    question about the ODOMETER
    when i start the car, it shows 99.9 - a few miles later , it jumps to 32 mpg , a few miles after that 17 mpg ... then it rises for the next 30 miles and STAYS at 44 MPG
    I have driven 700 miles at this point. is this normal for the odometer to go from 99.9 to 32 then 17, then average out at 44 mpg
    it seems like it bi polar :) .... remember this is not per trip, where the mpg could fluctuate based on 30 miles, this is over 700 miles, so it seems like it should only move a few MPG from any given point
  18. felixm0510
    I
  19. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    That doesn't sound like an odometer to me. An mpg gauge is NOT an odometer. Odometers count distance in the upward direction only, in km or miles.
    Your initial mileage will always be poor when the engine's cold. That's true of all internal combustion engine cars. You just may not have realized it as you may have had no feedback mechanism.
  20. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Yes, something is wrong but perhaps not with the car. An odometer reads the elapsed miles, it should only go up, and should be linear with distance.
