Parking brake malfunction...autopilot on, computer is self aware and trying to kill me!
Discussion in 'Generation 1 Prius Discussion' started by Eli Andrews, Oct 7, 2012.
  1. Eli Andrews
    Eli Andrews New Member
    wa
    2002 Prius
    So I recently was burned in purchasing a used 2002 prius with 135k
    Yeah, I know I should've taken it to a dealer for an inspection. But that was not possible as it was a copart online auction. I assumed it would have hv battery issues as the previous owner had donated the car.
    The car is a delight to drive and gets 44mpg average and when I go down hill I get 95mpg over 30 miles!
    So I've taken the car to a dealer and they said the main HV battery has one dead cell $4gs to fix.
    I don't really care as the vehicle still gets good mileage and since I paid $3000 for it I can't justify dumping that much into a prius that is not worth $7000. The service advisor and tech said it was safe to drive...(Yeah right!)
    I have since found out that the previous owners took it to the dealership and I assume they were told to get rid of it. Here's where it gets confusing. This dealer said the main ecu computer needed replacing as well as the battery.
    Every time I drive it the parking brake light comes on suddenly and will not disengage without turning the car off. Completely at random 5 miles or 100. Last night it did it twice within 15 miles. This to me is worthy of a recall! It is terrifying traveling at speeds of 70 mph and having the parking brake engage. There is a sudden revving of the engine and instant deceleration that will not respond to the pedal being pushed further down. To me having owned 6 toyotas all prior to the recall years I am furious. I feel cheated by the brand not the auction company. Remember "oh what a feeling"? Well it's a feeling of sheer terror!
    I can't get a straight answer from a dealer and wonder if the ecu being replaced would fix this dangerous problem? Besides this the car is fine. But I am afraid I might die one day driving it. Gas is over $4 a gallon and my tacoma 2.7 and 4runner 3.4 both get about 16mpg in town and I just can't afford to drive them anymore. What should I do? I cannot sell this car as it has too much wrong with it and I could get sued. It does have a clean title but clearly serious mechanical/computer issues.
    I found an ecu that was used on craigslist but don't want to pay to put it in if this won't fix the parking brake deciding to engage.
    My tacoma has a broken parking brake cable and since its a stick I don't feel a need to fix it, why can't I just cut the f&^%er off? or pull a fuse on the prius? Suggestions or solutions will be repaid in good karma.
    Oh and the parking brake releases and engages manually fine.
    -Autopilot off please!
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    ** Moderator note: Moved to Gen I forum **
    The "parking brake" light may also be indicative of a bigger problem - not that the parking brake is "engaging". Are there any fault codes that the dealer has attempted to pull on your behalf? If the engine is revving, there's definitely something else going on.
  3. John H
    John H Senior Member
    2,208
    558
    If there is only one bad cell, I think you can replace it for a lot less than $4k if you are a DIY type person. If you are close to an independent Prius shop, you might be able to have them try swapping a known good ECU and see if that clears up the problem. If not, the shop might want your Gen 1 for parts for other customers.
  4. Eli Andrews
    wa
    2002 Prius
    I am sure Toyota is just trying to drum up some work for themselves.
    The codes that the dealer listed were all hv battery codes.
    I may start with the ecu then if that doesn't work, I'll just drive it to the previous owners house and park it in their driveway so they can donate it again. I can't afford a hybrid car disposal fee.
  5. northwichita
    481
    102
    29
    Wichita KS
    From reading other somewhat similiar threads, you are much more likely to have a bad hv battery cell(s) than bad ecu. Consider easing up on the drama (its trying to kill me) and doing some research on the car and repair options.
  6. Eli Andrews
    wa
    2002 Prius
    If you would have read the post completely its both, ecu and hv battery. Sorry I don't have $5000 to waste. These cars are garbage and I should have bought a TDI
  7. youngnbald
    youngnbald Junior Member
    66
    Bloomington, Illinois
    2001 Prius
    I
    You come here for advice and then rip into people? That gets you far in life? It is sad to read these post and all the complaints from people that say all these cars are crap because a repair is needed. Pay for your other vehicles fuel cost and compare it to the cost of a Prius. I have $4000 in my Prius and it is going to pay itself off in one year with fuel savings alone! Do the math before ripping people apart for helping you. Sorry you're broke and the end of the world is on you.
    "Gas is over $4 a gallon and my tacoma 2.7 and 4runner 3.4 both get about 16mpg in town and I just can't afford to drive them anymore."
    Sell one and use the money to fix a low mileage Prius! I have over 280,000 on mine and love it after I invested the money to fix it right and now the rewards.
  8. bwilson4web
    16,324
    Just a couple of suggestions:
    1. Get a Prius aware scanner - at the low end, $150 Scangauge II and program in XGAUGES to read out Prius specific codes and data values. This will replace "so and so said" with facts and data. If you have a Windows laptop, ~$500 for AutoEnginuity would give you all of the functions pre-programmed.
    2. Traction battery replacement costs - prices vary from ~$100 module replacement and your labor; ~$1,700 ReInvolt pack and your labor, and $2,300 Toyota + their labor.
    3. ECU doesn't make sense but there is a Toyota TIS on it.
    If you can contribute your labor and shop, you potentially have a very useful car. Absent a Prius aware scanner, no one knows. But 10 year old cars are likely to require significant repairs, it comes with the territory and explains the value of having a warranty.
  9. John H
    2,208
    558
    Would the $29 techstream stuff on ebay do the trick ?
    Single Cable 2012 Newest V7.1.030 MINI VCI for Toyota TIS Techstream Hot Sale | eBay
    Any experience with this kit?
  10. bwilson4web
    16,324
    I don't have any direct experience. My understanding is a Chinese 'knock-off' of the TechStream-Lite adapter and there are . . . pirate-like versions of software around. I understand some folks have gotten it work but I'm not one who has even tried.
    I did buy AutoEnginuity and their $500 package with the Toyota option works pretty good. More importantly, the developer continues to improve the product. So I would recommend that approach before dealing with pirated stuff.
    ps. My problem with pirates is someone who would 'steal' for you would 'steal' from you.
  11. Gen1guy
    Gen1guy New Member
    47
    2002 Prius
    Mine did the exact same thing when I bought it with a bad traction batter....rebuilt with Gen 2 cells no problem now... Get the EXACT codes toyota read and we'll get ya through this...when the aux battery or Traction pack have issues the whole cars gets funny... No worries though stay calm cool collected and we can help you fix this ,after for maybe less then $100 if you have some basic mechanical and electrical knowledge!
    Have fun !
    Eric
  12. electrontechnik
    117
    31
    I have a suggestion...if the brake light is coming on on the dash, check the brake fluid level in the engine bay...it could be low. Mine was coming on until I found that it had dropped below a certain level. Top it off at the indicated level on the brake fluid reservoir and the light should stop coming on.
  13. usnavystgc
    3,159
    990
    Tucson, AZ
    I'm having a really hard time understanding how the brake engages by itself???? The parking brake is mechanical. There is no way for it to "engage" by itself. Either way, I would not drive the car in its current condition.
    As for your other complaints: You bought the car at an auction for $3000. What did you expect to get? Your expectations are severely unrealistic. Cars are auctioned for a reason. Its a chance you take. You gambled and lost. That's not Toyota's fault.
  14. ChapmanF
    18,446
    I'm pretty sure the OP really means the "BRAKE" light is coming on, not that a poltergeist is actually ratcheting the parking pedal down (though that would be really cool. Scary, but cool). But, as elecrontechnik pointed out, the BRAKE light comes on to warn of specific conditions described in the manual; it doesn't only mean the parking brake is engaged.
    -Chap
  15. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Google returns this description under the copart.com search listing: Copart auctions used and salvage vehicles to auto parts dismantlers, rebuilders, used car dealers, wrecking yards, and the public for insurance and rental car ...
    My interpretation is they sell junk. When one goes to a site that sells project cars one usually buys a project car.
    Go to Toyota Owners Official Website: Service Coupons, Owners Manuals, Service Scheduling and More to register the VIN & get the dealer service history. When shopping for a vehicle, research first, buy second.
    bwilson4web likes this.
  16. joedirte
    joedirte Member
    281
    58
    ohio
    2003 Prius
    I
    You bought a car from a salvage auction and won't spend the maximum $2000 for new battery. Yes, a Prius isn't happy without a working battery. Just like if you bought a TDI at auction with a broken fuel pressure regulator.
    usnavystgc likes this.
  17. FatGuyInATightPrius
    FatGuyInATightPrius New Member
    2001 Prius
    I
    I picked up a 2001 Prius with a bad battery back in early September and drove it with the exact same symptoms you're describing. The BRAKE light comes on, it won't drive beyond 40MPH.... it's your car telling you that it's hurtin and you need to get me fixed soon. I drove it for a month like that. I picked up a rebuilt battery for $1,645 (actually more like $2k since I'm keeping the core) and replaced it in about an hour. Super simple and now for a $3800 total investment I have a dependable car that gets amazing gas mileage. I'd do it again in a heartbeat.
    My back did hurt for 2 days after though... It's a heavy one-person job.
    P.S. Bob Wilson, it was your articles that gave me the info and confidence to yank out the old battery and put in the new one. I appreciate your wise words and attiude.
    C Clay and usnavystgc like this.
  18. Eli Andrews
    wa
    2002 Prius
    So 9 months later and I did everything you guys have suggested. I took it to a HV battery specialist here in Washington who specializes in reconditioning HV batteries. He located the bad cells and replaced them with working cells. This did not fix the problem. Now its looking like an inverter, ecu, tranny and who knows what else. Apparently one of the cells had arced, caught on fire and the dealer lied. It was 6 bad cells. Now I've got thousands spent on repairs with no working vehicle. I should have driven this thing straight into the ocean. It is a lost cause and I am out the price of a higher mileage 2nd gen. This is by far the biggest money pit I've ever had the displeasure of dealing with. I appreciate the advice but none of it worked and I feel like there needs to be a class action lawsuit against Toyota for deceptive marketing. Oh what a feeling! Complete disgust! **** Prius I and every one on the road. Ticking time bombs waiting to murder your whole family. I should have bought a TDI!!!!!!!!!!!!!!!!!!!!!!!!!
  19. bwilson4web
    16,324
    Comments inserted.
    I do not remember seeing any postings of NHW11 codes or traction battery metrics, something a Prius-aware scanner would accomplish. Also, I don't see using TIS or references to the two volume Maintenance manual. These are part of my standard recommendations.
    Perhaps you might invite him to join us here and share what he found?
    What are the Prius codes and OBD metrics?
    How did you diagnose this? Do you have photos?
    Now I've got thousands spent on repairs with no working vehicle. I should have driven this thing straight into the ocean. It is a lost cause and I am out the price of a higher mileage 2nd gen. This is by far the biggest money pit I've ever had the displeasure of dealing with. I appreciate the advice but none of it worked . . .
    It would help if you could share some of what was suggested. In particular, getting a Prius-aware scanner and sharing the codes and metrics.
    . . . and I feel like there needs to be a class action lawsuit against Toyota for deceptive marketing. Oh what a feeling! Complete disgust! **** Prius I and every one on the road. Ticking time bombs waiting to murder your whole family.
    A used Prius is not for everyone and the older NHW11 requires some mechanical skill, a Prius-aware scanner, and the diagnostic information. These are not things that can be outsourced cheaply.
    Sounds like we probably agree.
    cwerdna likes this.
  20. Eli Andrews
    wa
    2002 Prius
    @ Bob Wilson.
    2002 Prius update. Finally outsourced some cheap parts and labor. The last guy was close but didn't have the know how. Replaced 3 more cells and balanced the pack. The new harness was okay but still corrosion that needed to be cleaned. I paid the Ukranian genius $350 and my car is back online. I apologize for all the angry posts earlier however it was upsetting to get a $5000 quote from the Toyota stealership.
    The car just clicked 140000 and I'm sure a few more cells will go bad in the future. @$25 a pop I think I can manage. I still think that Toyota should fix the loss of power issue when cells go bad. I'm surprised no one has been severely injured or killed. I'm glad I didn't part it out or sell it to the last guy that tried to work on it for $800 (his offer)
