If the Prius has no belts. WHY IS THERE A CRANK PULLEY?
Discussion in 'Gen 3 Prius Technical Discussion' started by 3rdgeargrndrr, Oct 8, 2012.
  1. 3rdgeargrndrr
    3rdgeargrndrr New Member
    Ok to start off i had the rough start issue yesterday. When looking at my engine bay i noticed there was a crank pulley with no belt. I thought for sure i had shredded or lost a belt but the gen 3 is beltless so why do we have a crank pulley? Rotational mass? Timing? Or did i miss something?
  2. F8L
    19,011
    4,081
    Grass Valley, CA.
    So tuners can continue to install under drive pulleys and feel like they are making more HP? :ROFLMAO:
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,531
    Southwest Colorado
    Mean. <<snicker>>
    OP: I wondered the same when I first saw it :)
    I was told it works as a flywheel. I presume for rotational energy when the ICE no longer needs to rotate.
  4. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Timing. TDC #1
    cwerdna likes this.
  5. David Beale
    David Beale Senior Member
    5,963
    1,982
    Edmonton Alberta
    It is first off a crankshaft -dampener-. Without it you would trash the bearings. Using it to drive belts was the 20th century solution to make the car work. In the 21st century we don't need the belts any longer. Except on those still making obsolete cars. ;)
    WE0H likes this.
  6. ngc4565
    ngc4565 Member
    156
    17
    Pennsylvania
    It is probably a harmonic balancer, aka a crankshaft dampener as mentioned above. Don't lose any sleep over this, and continue to enjoy your Prius.
    Prii_Ownr likes this.
  7. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    The same basic engine is used on the Corolla and Matrix, so they probably kept the belt groove features on it for the sake of having a common part. Otherwise, a plain flywheel would probably work.
  8. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Tradition???
    Seth the Younger and WE0H like this.
  9. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    420
    Whereabouts Unknown
    It connects the optional warp-drive transducer to the space-time converter.
    Seth the Younger, Blu-ray and WE0H like this.
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Where else are we going to attach the drive belt for that hypothetical bolt-on supercharger?
  11. WE0H
    WE0H Senior Member
    3,247
    527
    Yea slap a M-60 on there with a 2.9" pulley. Tire smokin Prius [​IMG]
    Mike
  12. Bradley R Beaver
    Bradley R Beaver New Member
    Akron pa
    2017 Prius v wagon
    Probably cheaper to mass produce the same pulley
