Stiffening Plate - Any Problems?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by highlander1010, Jan 11, 2006.
  1. highlander1010
    highlander1010 New Member
    24
    Seattle, WA
    I see a lot of great stuff here about the stiffening plates. I'm wondering if anyone has had any problems with theirs? I don't want to be negative, but I want to know if there have been any flaws discovered?
    Just curious. Thanks. :lol:
  2. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    So far the only down side has been that I had to wait a whole week and a half for it to arrive!
    Seriously though, it's a great item and I really don't see any potential issues with it.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    86
    It takes maybe 10 minutes (being generous) to install the plate, and your car is completely undrivable during that time. After that you'll want to drive your car a lot since it handles so well.
  4. psirus
    psirus New Member
    SF Bay Area
    No problems at all -- though in addition to being unable to drive your Prius during installation, you may be upset at how much pleasure you missed during the time you drove it BEFORE installation.
    Seriously, this item makes such a difference, it is hard to believe. I am still puzzled how some find the difference only "subtle," or imply that noticed improvements are surely t he product of imagination or wishful thinking. Surely, they think, if such a small modification can make such a difference, Toyota would have done it themselves. Well, they didn't and it does!
    Tracking, steering, even the function of the accursed OEM tires all are markedly improved.
  5. Twiddles
    Twiddles New Member
    47
    Downstate NY
    I installed my stiffening plate about a month ago and agree with all of the above. Cornering, in particular, is greatly improved. Before the plate I used to slow down to a crawl in a turn. Just didn't feel safe. It felt like the rear of the car was going to fish-tail. With the plate installed I can slow down a little before the turn and accelerate into the turn and the car feels solid and safe.
  6. djasonw
    djasonw Active Member
    961
    123
    Coconut Creek, FL
    I have had the plate on for six months and it makes a HUGE difference. I agree with all the above posts and really can't add much more myself. Get it, you won't regret it.
  7. canadianimport
    canadianimport New Member
    Livermore, CA
    I've seen the stiffening plate listed here on PC. Is that the one people would recommend (or is there anyone one to purchase from elsewhere)??
  8. JackDodge
    JackDodge Gold Member
    2,366
    Bloomfield Hills, MI
    I must be missing something. Have you ever been driving any car while something's being installed on it? While my tires were being replaced, it was undrivable, right? :rolleyes:
  9. Michael Maddox
    Michael Maddox New Member
    47
    Tallahassee, Florida USA
    Hence the joke, man.
    Hey! Look! "Gullible" is written on the ceiling! :lol:
  10. JackDodge
    2,366
    arrr arrrr arrr....well, don't give up yer day job.
  11. malibucarl
    malibucarl Member
    237
    Malibu, Ca
    No problems. Makes a noticeable difference. Will add the spoiler soon and see what, if anything, that does.
    Carl
  12. kinged
    kinged New Member
    81
    I have 06. It drives fine. How do I know if stiffing plate going to make any difference? Anyone with 06 tried it?
  13. bbianchi
    bbianchi New Member
    89
    Fresno / Monterey CA
    Yea my 06 doesn't feel like it would benefit from one...?
    Is this plate only for 04-05?
  14. mcmurray
    mcmurray Junior Member
    52
    Gold Coast, Australia
    Yea - I would like an answer to that one too!
  15. DocVijay
    1,455
    Tampa, FL
    There are several people and many posts about 2006's with the stiffening plate. Anyway, I'll go ahead an post here too.
    I installed this on m 2006. It's fully compatible with it. There has been no change from the 2004-05 models with regards to the stiffening plate. I noticed a difference after I installed it. I highly recommend it.
  16. Jaguar88
    Jaguar88 Member
    172
    La Crescenta, CA
    I remember seeing sombody change a tire on the car while it was being driven. I think the late sixties or early seventies. They weren't going very fast though.
  17. BT Tech
    BT Tech New Member
    885
    South Florida
    I want to jump in here and give my experiences with an installation that I just did today on a 2006. I spent a few hours at our local dealership and examined the 2006 with a fine tooth comb.
    From what I could see there were no appreciable changes to the chassis/body compared to the countless 2004 and 2005 that I have seen.
    Our BT Tech stiffening plate bolted right into position perfectly on the 2006 just like it does on the 2004 and 2005 model year cars.
    Other than the small interior changes in the vehicle the only other change that I noticed that was slightly different was with the front windshield. It seems to be made out of either a thicker or differnt type of glazing. It might even have a thicker laminate layered between the glass for added sound rejection. Taking my hand and knocking on the windshield on the 06 vs my 05 definately had a different "ring" to it.
    There was talk that Toyota changed the struts and spring rates as well but without comparing part nubers between the 04, 05 & 06 MY cars it would be difficult if not impossible to tell.
    Applying pressure at all 4 corners and watching the amount of rebound was about the same for all model years.
    Hope this helps..
    Thanks!!
    Brian
    BT Tech
    305-652-3115
  18. benighted
    benighted New Member
    530
    Westport, WA
    I've had my stiffening plate for about 2 months now and I noticed there is less body lean in corners and is slightly more responsive. The difference is probably most noticable with the stock Integritys but I have Toyo Proxies TPT on mine.
  19. pjm877
    pjm877 Member
    340
    84
    austin, tx
    problems with the plate.. well no but a quick trip to Sears solved the problem I had with the bolts ;) All those $100's of tools and I did not have one for these darn bolts.. do now..
    The plate made a big change for the better for me... Toyota you reading... BT is hoping not :)
    So if my Prius is totaled... I remove the plate, xmradio... to put on my Prius replacement..
  20. bbianchi
    bbianchi New Member
    89
    Ill offer to "beta" test one on a 2006 for you ;)
