2005 Prius Maintenance Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by PRwanting, Oct 12, 2012.
  1. PRwanting
    PRwanting Junior Member
    48
    Boston, MA
    So I bought a prius about a month ago (used 2005) and I'm gonna do the oil change tomorrow. It's closed to 60000 miles. I was just wondering what services should I look at or need to look at besides regular oil change? I looked at the filters. Those r fine.
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I'd get the transaxle fluid changed pronto. A dealer should charge ~$100 for the fluid and labor.
  3. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
  4. PRwanting
    48
    Boston, MA
    Hi all, thanks for the replies. Appreciate them. Transaxle fluid is the same as automatic transmission fluid right? I usually get my oil change at Meineke. Can I get the transaxle fluid change there?
  5. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    You MUST use Toyota ATF WS. Do NOT use any other transmission fluid (e.g. Dexron).
    I would also test the 12 volt battery via the procedure at Weird stuff happening? MPGs dropping? Test The Battery | PriusChat after the car has sat overnight. Tell us the voltages levels at each step. We should get 3 of them.
    Since the engine on the Prius isn't started by the 12 volt, you will NEVER get symptoms of slow cranking or starter being enable to turn the engine (Prius has no dedicated starter motor). If it's still on the original 12 volt, it's almost certainly toast now and you'll experience weird problems soon, if not already.
  6. PRwanting
    48
    Boston, MA
    If I tell Meineke to use that (TOYOTA ATF WS) is it safe to do the transmission change over there or I HAVE TO take it to the dealer?
  7. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
  8. PRwanting
    48
    Boston, MA
    The dealer quoted me $70 for drain and fill and $170 for the full flush. Which one do I need?
  9. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    Drain and Fill is all you need.
    (In complicated automatic transmissions some ATF may be 'hidden' and need a flush, in a Prius there is almost no ATF that is not ready to drain out}
    What is a Transmission Flush?
  10. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the maintenance forum
