Didn't fill up completely
Discussion in 'Prius c Technical Discussion' started by cmstlist, Oct 12, 2012.
  1. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    I am driving from Vancouver BC to Seattle, and I stopped at the Bellingham Costco for gas. My tank was at two notches and the pump stopped after 3 gallons. I tried again and it stopped again - a bit of fuel dribbled onto the ground.
    I started the car and was at 5 notches out of 10.
    I will try to fill again on my way home, but this hasn't happened before and it wasn't happening to the other cars in front of me. Should I be concerned?
    Galaxy Nexus ? 2
    52,284
    could be the pump, let us know how the next fill goes.
  3. Andy Tau
    Andy Tau atai
    This may be related to the thread of the running out of gas on the freeway (E.B.) with wrong display of the gas volume in the tank (so E. B. did not know he was running out of gas)?
    When I was filling up (San Jose, CA) last time (and the first time) the pump also stopped (as if the tank was filled) but I know that was not possible (only 3 gallons at the time) so I tried again and the pump resumed until filling about 7 gallons)
  4. cmstlist
    cmstlist Member
    183
    40
    Toronto, ON
    I know that the reading before the fillup was relatively accurate because I'd just driven about 700 km since the last fill :)
    Galaxy Nexus ? 2
  5. winnertakesteve
    154
    47
    Toronto ON
    2025 Prius Plug-in
    SE
    something similar happened to me, too. i was at 2 bars and tried to fill up, and the pump stopped at a half tank. had a moment of paranoia that it'd overflow if i kept trying to pump, so i just took the half tank. tried filling again at a different station when my guage got down to two bars again, and didn't have any issue.
    i read later that sometimes the if the fuel is being pumped too quickly it'll froth a little and trip the auto-stop mechanism or splash out a bit. never had it happen on any vehicles before though, so i do wonder if there is anything in the c's gas tank design that contributes to it happening? i'll keep an eye to see if it happens again, at any rate.
