Air conditioning question
Discussion in 'Newbie Forum' started by Valrayx, Aug 19, 2012.
  1. Valrayx
    Valrayx Junior Member
    Montreal
    2019 Prius
    Hi all
    Anyone know the cooling rating of my air conditiong unit (in BTU/h or kW) of my 2012 Prius Gen3?
    thanks
    Valerie
  2. Randy G.
    Randy G. Member
    113
    28
    Fullerton, CA
    It's better than my 2007 PT Cruiser, that I know for sure. We just bought a new level 5 and even in 100 degree heat it will freeze you out of the car if that's what you want (and I do).
  3. PriusInParadise
    180
    91
    Hawaii
    From the 2012 Prius New Car Features Manual:
    Heater
    Heater Output W 5200
    Air Flow Volume m3/h 330
    Power Consumption W 190
    Cooler
    Cooling Capacity W 4920
    Air Flow Volume m3/h 475
    Power Consumption W 240
  4. Valrayx
    Montreal
    2019 Prius
  5. Valrayx
    Montreal
    2019 Prius
    Thank you! You are better than the dealer! I missed it in the manual.
  6. F8L
    19,011
    4,083
    Grass Valley, CA.
    In terms of power draw the A/C can draw 1900w when going full bore. It drops to 1500w after a few minutes and eventually settles at 300-600w depending on outside temp and your settings.
  7. Valrayx
    Montreal
    2019 Prius
    How did you measure that?
  8. F8L
    19,011
    4,083
    Grass Valley, CA.
    If you meant to quote me I measured the power draw with the Torque App and a Bluetooth OBDII adapter.
  9. PruisAz
    PruisAz Member
    140
    34
    Mesa, Az
    Being in the Phx heat and using the ScanGuageII (ACw), the A/C does max out @1900W draw when first getting into your auto in the afternoons. Depending on the temps outside to cool and maintain the cabin, the A/C can draw from 0-200W in the mornings to 900W draw at @100f heat. I never had the auto when outside temps were at 115f and I wonder what it would take to cool the car.
    Yes, the A/C is ice cold and has no hardship even though its not running off a pulley belt like in gas autos. Considering the hot climate here, I don't think I ever ran the fan speed beyond 3-4 bars. Ever. The draw of the A/C would not matter if you had the fan on high or low.
  10. ken1784
    ken1784 SuperMID designer
    2,943
    1,383
    67
    Yokohama, JAPAN
