Have you experienced any problems with the C?
Discussion in 'Prius c Main Forum' started by prius1driver, May 20, 2012.
  1. prius1driver
    prius1driver New Member
    78
    New York
    4000 miles and zero issues so far.
  2. dig4dirt
    dig4dirt MoonGlow
    1,151
    741
    Lancaster Co PA
    2014 Prius c
    Just hit 1000 miles friday night.
    No problems
    I just filled up with 100% pure gas and now am getting consecutive mpg over 60
    I just checked my tire pressure and only at 37 or so,
    so I need to get a tire gauge and fill them up, as I will expect another 1-3mpg, since they are very low. Want to go to 42/40 or more (max on tire says 51)
  3. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    ove 3000 miles. no probs. its a toyota after all :)
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Why would you think there should be problems? The Prius is a proven and very reliable vehicle.
  5. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    6300 miles. some mild rattling, but it's mostly from me tinkering with the car.. lol.
    nothing serious, and no problems otherwise.
  6. crebble
    crebble Member
    176
    47
    Shohola PA
    Have had 2 minor issues in 5000 miles:
    1. Navi got lost and put my position about 30 miles off. Stayed that way all day, tried turning car off/ on many times and finally recovered on its own. Glitch, never repeated.
    2. Ice nearly stalled as I came down a hill in EV mode Was about to pull out onto a 55 mph road. . Gave the car some throttle, auto switched from EV to Ice, felt a thump and some of the dash lights flickered. Ice caught, started and ran normally. Never repeated and no CEL. Bringing it in tomorrow for 5 K service. May ask to see if there is a stored code.
  7. secondspassed
    secondspassed Member
    112
    26
    Corona, CA
    My driver window has started squeaking a bit sometimes when I roll it down.
  8. chivazo
    chivazo Junior Member
    31
    San Francisco Bay Area
  9. RocMills
    RocMills Active Member
    789
    277
    Las Vegas, Nevada
    2,300 miles here and not a single issue.
  10. lightsider
    lightsider New Member
    26
    Utah
    We're almost at 9k miles, have taken 2 major trips and no issues! I love my little Prius!
  11. Ryephile
    Ryephile The Technophile
    418
    151
    24
    Metro Detroit
    6,200 miles as of today and zero actual issues, knock on wood.
    I'm not used to cars being reliable & well-sorted, as I've had lots of British & German cars in my past.
  12. Tracy
    Tracy Member
    171
    101
    My USB connection cuts out periodically. I've notified the dealer and they'll check it out at my 5000 mark. It's not something I feel a burning need to make a special trip for.
  13. Banjo
    Banjo Junior Member
    17
    One month old and the MFD touch display would not work, I made a service appointment 2 days later the touch screen started working again. so far the problem hasen't repeated itself...I'm confident it will then Ill take it in for diagnosis.I really like this car,it fits me to a "T", however lots of electronics and in the long run could spell trouble. I have 3 years/36,000 to run it through its paces.
  14. BrunoPuntzJones
    107
    28
    Same, 6600 miles, some rattles, pretty much it.
  15. Mik1
    Mik1 Member
    333
    Houston, TX
    8300 here, no probs except the one I was b.... from the very beginning - panel rattling, that's it!
  16. photogrl13
    photogrl13 Member
    115
    47
    59
    Columbus, Ohio
    4k here and no issues whatsoever.
  17. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    5,700 miles no major issues other than some interior rattles.
  18. vernon birdman
    vernon birdman Active Member
    330
    141
    Vernon BC Canada
    11000 Kms and no problems at all
  19. RJphxC
    RJphxC New Member
    22
    Glendale, Arizona
    I noticed one of my rear doors makes a cling sound rather than the typical thud type noise other car doors make. I'm wondering if this is why I get so much wind noise when I get over 60mph. Also some marks on the interior, mostly on the doors. Not sure what caused them but it won't wipe off easily, which is about all I've tried. If these are my issues then I'm doing just fine. 2k miles btw.
  20. tom & lisa s c
    tom & lisa s c Junior Member
    47
    the only car that seems to have a break down had some after market electronics on it
