Vanity Lights Replacement
Discussion in 'Gen 3 Prius Accessories and Modifications' started by mad4sax, Oct 18, 2012.
  1. mad4sax
    mad4sax New Member
    26
    Marcellus, New York
    OK so I am almost done replacing all interior and exterior lights with LEDs.
    How the heck do you get to the bulb in the vanity lights?
    I have tried to remove the lens and then to pull the whole fixture out. No luck!!
    Any suggestions???
    I really hardly ever use them but I "need" to have all LEDs on the interior. :-D
  2. xliderider
    xliderider Senior Member
    8,126
    3,266
    Honolulu, HI
    I believe you need to remove the headliner first. I was looking at it in my pdf repair manual last week.
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    This is not true. I didn't have to do that when I changed mine. Let go look & I report back.
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    There is a tab that needs to be pressed that's closest to the door.
    Rosie Benitez and mad4sax like this.
  5. mad4sax
    mad4sax New Member
    26
    Marcellus, New York
    Thank You!! My quest can now continue. :)
  6. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    No problem
  7. Texas-Prius
    Texas-Prius One more Prius to fight terrorism
    79
    32
    Austin, TX
    Even with the tab, it feels like you are going to rip it through the headliner. With a very small screwdriver, and making sure you are on the side with the tab, it takes a VERY firm pull. Just make sure you are on the side with the tab. The way that I knew I was on the side with the tab, was to turn on the light. You will see that the bulb is not exactly in the middle of the housing. The bulb will actually be slightly closer to one side. This is the side with the tab.
    - TP
    mad4sax and sfv41901 like this.
  8. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Good point
  9. mad4sax
    mad4sax New Member
    26
    Marcellus, New York
    Thanks all for the help. New LEDs are now in the vanity lights. The tab was on the left side of both lights.
    Also changed the front signal lights today. Not as easy of a change! Well the bulb was but getting the resistors on the wires wasn't easy.
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Xterra72 likes this.
  11. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    What did you use? I used something like this - plenty bright.
  12. xliderider
    8,126
    3,266
    Honolulu, HI
    Got some of those on the way as well...
  13. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I used 2 of these in each map light, 1 in each vanity light, 1 in the door puddle lights, and 1 in the trunk. I used 2 48-SMD panels in the dome light- that's 204 SMD LED's - really nice and bright in there.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
  15. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    mine came in around $15.
  16. Texas-Prius
    79
    32
    Austin, TX
    I spent a total of $7.19 by purchasing cheap wedge bulbs with 5 SMDs mounted on them for all of the lights (.75 each from Amazon), except for the two fuse bulb like lights, where I purchased cheap bulbs with 9 SMDs mounted on them (2.69 for the pair from eBay). They are putting out more light than the stock bulbs, and I can't imagine wanting any more light.
    - TP
  17. SoCal65SS
    SoCal65SS Member
    72
    44
    Southern California
    Is there a listing (or do you know and can share here) of what size bulbs go in each location? I had looked at the jdmtoys kits before and had second thoughts not wanting to spend nearly $100 on the lights. But $15ish I could live with.
  18. Texas-Prius
    79
    32
    Austin, TX
    SoCal65SS likes this.
  19. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    I tried these at first in the map lights and they didn't shine bright enough, so now they light up my license plate.
    Imagine 96 in there :D
  20. Texas-Prius
    79
    32
    Austin, TX
    I'm sure the lumens of 96 SMDs must equal the output of the sun, but for me, the stock bulbs were bright enough. My goal was to decrease the amps used when running the lights. Also, I had accidentally left one of the vanity lights on one time over night (back when it was stock), and I was fortunate that it didn't run the 12V battery down. With the LEDs I'm running now, I know that won't be an issue. However, if I'm running 96 SMDs, I don't know if there is much of an amp savings.
    - TP
