A really dumb question
Discussion in 'Gen 3 Prius Main Forum' started by Carnutt, Nov 8, 2009.
  1. Carnutt
    Carnutt Member
    232
    SW USA
    2018 Prius
    Does the center console open, not just slide, to reveal a compartment/storage area besides the second cup holder? Someone told me it does but mine doesn't.
  2. qbee42
    3,079
    Yes it does.
    Edit: I just reread the question. I'm not sure I know exactly what you are asking. Can you rephrase it?
  3. Midpack
    Midpack Member
    461
    43
    Chicagoland
    The one I drove did, but the dealer had to show me the trick to sliding it open...
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    It slides back to show a second cupholder. Then it slides back more and when it stops you can flip it upwards to get into the armrest storage compartment.
    Now, the second cupholder is an insert that can be removed from the front part of the center armrest storage compartment. Maybe your insert is not in there so all you have is one big open compartment area.
  5. ctmurray
    ctmurray Member
    121
    This insert "hangs" on some supports and can be flipped upward to get at more of the compartment. So I agree your adapter / insert is missing. I do miss the design of my 2007 prius regarding the two cup holders. Probably my only complaint or design change I notice.
  6. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Your question is not "really dumb"...not even a "little dumb".
  7. DavidA
    2,347
    1,822
    Chicago western burbs
    Additionally, the small flip tray inside the main compartment can also be removed. Since the storage bin is quite a bit smaller than the GenII, many GenIII owners have removed both the cup holder and the flip tray to gain much needed room.
  8. eglmainz
    eglmainz New Member
    887
    141
    Chicagoland, IL
    To answer your question, as I think that all the other answers have not answered you, yes it does lift open as well as slide back. Just as you did to release it when you slid it back, there is a release switch under the forward edge of the lid. If you pinch that, in order to trigger it, you will be able to lift the lid upwards.
    However, it will not slide upwards until it is slid back all the way first. Please try that, and let us know if it helped.
  9. Carnutt
    Carnutt Member
    232
    SW USA
    2018 Prius
    Precisely what I wanted to know, thanks :D.
  10. D Colegrove
    D Colegrove New Member
    Does anyone know where to purchase the 2nd cup holder insert that goes inside the Prius? I've searched online but can't find it.
  11. jppicks
    jppicks Junior Member
    El Segundo, CA
    Anyone happen to have a video of this?
  12. Selzier
    Selzier Whee!
    148
    51
    Does this apply to 2012 models? I've pushed, pried, pulled, prodded, twisted, yanked, tugged, tapped, knocked, hit, pounded, shaken, sweated, cried, cursed, screamed, yelled, begged, prayed, said "open sesame", given up, came back, baby-talked, delivered a hand-written note, bought a gift, wined and dined, read the manual, stared helplessly, and asked for friends to look at it and nothing in my center console "slides".
    Is this in a certain section I'm not aware of?
    Spokanepriusgrl likes this.
  13. kingka
    kingka New Member
    the 2012 version does not have this
  14. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    You should have asked here before you pushed, pried, pulled, prodded, twisted, yanked, tugged, tapped, knocked, hit, pounded, shaken, sweated, cried, cursed, screamed, yelled, begged, prayed, said "open sesame", given up, came back, baby-talked, delivered a hand-written note, bought a gift, wined and dined, read the manual, stared helplessly, and asked for friends to look at it because we could have just told ya' that for 2012 the center console is no longer a sliding console cover anymore. ;)
    fuzzy1, Spokanepriusgrl and Selzier like this.
  15. Braddles.au
    Braddles.au DEFAnitely using an EBH
    295
    99
    Canberra, Australia
    You forgot the magic word, "Please". [Tuts loudly]
    Selzier likes this.
  16. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    The second cup holder can also be used as a cup in an emergency when a three year old need a drink.:)
