Poor Sirius reception
Discussion in 'Gen 2 Prius Audio and Electronics' started by preludedude, Jan 13, 2006.
  1. preludedude
    preludedude Junior Member
    29
    Okay...I just had Sirius professionally installed in my Prius, the kind that runs through the display. (AKA...Toyota sells it as Prius compatible, but it really is a Solara unit.) Great, terrific, antenna is ugly, but who cares.
    Well, on the drive home, the reception I got was TERRIBLE! Anytime a song came on, the speakers were full of crackling and static, especially when the singer...sang. Obviously, if I'm paying for Sirius, I want those issues to NOT happen! CDs were crystal clear.
    Could it be that I haven't officially called Sirius to subscribe and register my unit? Let me know. I do know that when I had Sirius put in my Prelude, I experienced nothing of the sort...in fact, on the drive home from the installer this evening, I thought it odd that I was receiving all the channels, instead of just the "Welcome" channel.
    I hope the solutions is as simple as that, but I DO know that the crackling speakers delivering my Sirius signal has to be taken care of.
    Does anyone have any advice? Thanks!
  2. larryenok
    larryenok New Member
    44
    My guess is a defective unit, but it also sounds like a shorting wire from the Sirius receiver to the Prius unit. CDs would play okay because of the wiring being internal to the head unit. The Sirius receiver is a separate unit. Your professional installer may need to look at his work again. :(
  3. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    I'm pretty sure it's not your reception. Digital audio is either there or it's not. It's not like an analog signal like FM or AM that can become distorted by interference. If the reception is bad enough that it can't reliably receive the digital signal, then you would have audio drop outs (periods of silence) not static. If you're hearing static or crackling, then it's something else.
    I vote for a loose connection between the Prius radio and your Sirius radio.
  4. priusenvy
    priusenvy Senior Member
    1,765
    Silicon Valley, CA
    I'm absolutely sure it isn't.
    What he said.
  5. mdmikemd
    mdmikemd Member
    436
    Minneapolis
    I have a Sirius plug and play. I don't have a direct FM connection, I just put my radio to 88.1. What i've noticed is the reception isn't great. When I do this in my house, I can turn on a radio 20 feet away and get good reception.
    With all the reports I'm seeing on Prius Chat, it makes me wonder if there is some interference inherent in the Prius. I don't get this on my Sienna.
    Frankly, the static doesn't bother me. I'm no audiophile.
  6. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Yeah, but the original poster is not using an FM transmitter (neither a direct antenna connection or an over the air kind). He's connecting the toyota Sirius radio directly into the jack on the back of the headend.
    I would bet that the audio connection between the Sirius radio and the Prius headend is an analog signal. Therefore a poor connection on that line could result in static, particularly if vibrations are affecting the poor connection, but even if that's not the case.
    Alternatively, a poor connection on the power or ground lines, which run through that same cable, could provide a poor power supply to the Sirius radio and could also produce static or crackling.
  7. IndyDoug
    IndyDoug New Member
    120
    Indianapolis, IN
    Is there anyone with the Toyota Sirius unit that can post something good?
  8. priusenvy
    1,765
    Silicon Valley, CA
    I've had zero issues wth static or a bad connection. Quality is about equal to a strong FM station, not as good as CD. I believe that's due to the compression and I am hearing what is being uplinked. My only issue is that I lose the signal more often than I expected, whenever driving near tall obstructions (trees, buildings). I thought the Sirius satellite were high enough in the sky that I'd have to be really close to the obstruction, or the obstruction would have to be really tall before I lost the signal.
    I'm not sure whether the antenna being mounted on a sloping portion of the roof has anything to do with losing the signal. In any case, I would not want to drive a Prius w/o satellite radio of some kind. Most of the complaints appear to be from people with crappy installs.
  9. robinsod
    robinsod New Member
    37
    Kerrville, TX
    Sirius? I have XM and no problems. Perhaps the BS detector is enabled.
    :D
  10. BassMasterK
    BassMasterK New Member
    22
    Your problem may be caused by a nearby radio station that is either using 88.1 or one of the next frequencies on either side of it. Check your plug and play's manual, there should be an option to pick a different frequency that your plug and play will broadcast on. If you can find a 'quieter' frequency it should help your reception.
  11. BassMasterK
    22
    The first thing that jumps out at me is that you were recieving the channels on the way home without activating the unit first. Unless the shop that did the install walked you through the registration at their shop, it sounds like you got a used unit. I have read of people who bought a 'new' unit that looked used and it turned out it was used and the deactivation of the unit never was done or didn't go through. If this is the case, then it could be a defective unit that someone else turned in for a refund and either didn't tell them that it was defective or the dealer accidently put it back out for resale and didn't pull it.
    Some other questions I would have if the unit turns out to be okay:
    Does the 'crackling and static' sound more like a sizzling sound or definately a hard crackling sound? If it is more of a sizzle, then it could be antenna related. If the signal gets too low, on the edge of dropout, you get a high end sizzle sound that accompanies the audio. If this is the case I would ask two more things.
    1) Where was the antenna installed?
    2) You mentioned the antenna was 'ugly'. Is it the big square box antenna, or the small circular antenna, or some other type? I have read that the big sqare box antenna's blow and that the ciruclar type have twice the gain. I havn't seen the numbers, just repeating what I have read. It could be a combo of crummy antenna along with poor antenna placement.
  12. fulostix
    fulostix Junior Member
    42
    My sirius sounds fine...I placed the antenna on the rear of the car to the right of the FM antenna...sounds like a defective unit
  13. preludedude
    29
  14. preludedude
    29
    Unfortunately, when I bought the unit, I believe that MetroPN told me I could not return it b/c it was not for the Prius. I'm taking the car back to the installer today, and praying that it's not a defective unit. If it is, I'll get it taken out and see if they'll exchange it; if they won't, the BBB will hear about it.
    The thing about the reception is this...I get good reception for about 15 minutes, then inexplicably it drops out, regardless of where I'm at. So obviously that's an issue as well. I'm about ready to throw up my hands and get a plug-n-play unit, as unappealing as that is...having the stations on the diplay is really cool.
    Nothing is every easy... :angry:
  15. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    I vote for bad unit now, although it could still be a poor connection.
    If it works fine for 15 minutes and then craps out, then my guess is that after 15 minutes the unit warms up to the point where a defective component fails or a bad solder joint fails.
    If the unit truely is defective, I would think that Metro TPN would replace it.
  16. BassMasterK
    22
    Something that may help you with your arguement is that unless they walked you through the registration process with sirius and you bought a plan there with your credit card, you got a unit that had already been activated. That means someone else had already used your radio and returned it. When you get a new unit, you only have access to one channel and the unit says "call sirius to activate".
  17. fulostix
    42
    Yeah you make a good point. I bought mine from Metro as well, and tell them you had an installer put the unit in properly...and tell them you just want to exchange it. It shouldn't be a problem...at least hopefully...and if they tell you it's not for the Prius...then tell them why does it say on their website "2004-2006 Toyota Prius"
  18. preludedude
    29
    Ah, the serious Sirius plot thickens, and so far, there is no happy ending in sight...
    The tech who installed my unit agreed with you fine people that the unit itself was probably defective, and added that it was possible the unit was used, because as soon as he installed it and turned it on, I got all the channels, not just the test channel. He did say that he can't know FOR SURE that it's the unit; he did go through and check all the connections etc and it all checked out fine. He did say it could be the antenna. This is a reputable shop that has done these units before, usually for XM, in the Prius.
    Cool, that's done...Next step, call Metro and have them swap me another unit. Not so fast, Metro said. They fell back on the old "It wasn't made for a Prius" line, though they sell it as such. He told me he'd have to see how the warranty would work since it was installed in the Prius. He did not seem happy to have to deal with me. He said he'd get back to me within the week; he seemed to think I was trying to screw him over, or that the shop who installed it was staffed by crackheads.
    He called me back in half an hour. Are they SURE it's the unit? he asked. I made the mistake of saying what the tech told me: he's pretty sure. Well, he said, that's not good enough. In order to get my unit swapped, "the customer and the third party" have to be absolutely sure it's the unit, not the antenna or the connections, or my Aunt Betty. He told me if the receiver is returned and it's NOT defective, "we'll be in trouble." By whom? I wondered...
    So, I have to go back to the installer, pay him $50 an hour, and try and rule out other culprits before the receiver is swapped.
    I can hear some of you saying I should beat down the doors and demand justice from Metro, but I'm going to work with the installer and see what they have to say...in the next couple days, that is, as I'm Sirius-ly burned from this whole experience.
    Thank you for your support! How I envy you who have had no problems! At the very least, this should serve as a cautionary tale for all of you...
  19. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    Have you talked to Eddie Bell at Metro? He's the one who created the installation instructions and their website says "Still have questions? Give us a call 877.885.2900 ask for Eddie."
    I have no idea what standing Eddie Bell has in the organization, but personally I'd call the number and ask for Eddie.
    As for the "It's not for the Prius so you can't return it" line... As other's have pointed out, their website says it's for the Prius.
    And they probably get very few people who walk in to buy one of these. I imagine their business on the XM and Sirius radios is mostly over the internet. As such, the guy behind the desk may be clueless.
  20. preludedude
    29
    The famous Eddie Bell is on medical leave, according to Jesse, the new guy on the job. Based on his attitude, I'd say that it is not a job he took by choice. When I first began shopping for a satellite unit, it was on ebay, and that's how I discovered that Metro sold these units. But when Eddie disappeared, so did the ad on ebay.
