Anybody good at math?
Discussion in 'Gen 3 Prius Fuel Economy' started by kalome, Nov 1, 2012.
  1. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Can someone please help me get the average miles per gallon for my work round-trip including lunch round-trip?
    I take the freeway to work which is 16.7 miles. Lunch round-trip 3 to 5 miles. Take surface streets home from work 12.5 miles.
    Going to work I get anywhere from 56 to 60 miles per gallon, dash reading. Lunch round-trip depending on where I go could be as low as 50 miles per gallon. Going home from work anywhere from 82 to 88 miles per gallon.
    So a low estimate average:
    58 mpg for 16.7 miles
    84 mpg for 12.5 miles
    50 mpg for 3 miles
    58 - 51.86% of the 3 routes
    84 - 38.82% of the 3 routes
    50 - 9.31% of the 3 routes
    What would be the average miles per gallon for all 3 routes?
  2. markabele
    5,084
    1,782
    Nebraska
    Codyroo likes this.
  3. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Could you show me how you arrived to that average?
    A straight average without using distance would be 64.
  4. schlem
    schlem Polygeek
    82
    39
    Ballard, C@L
    I would set a trip computer for the day and let the ODO average all the mileage, but I think the math is relatively simple.
    58 MPG X 16.7 Mi = 968.6 Mi^2PG (to coin a unit: "Miles squared per gallon")
    84 MPG X 12.5 Mi = 1050 Mi^2PG
    50 MPG X 3 Mi = 150 Mi^2PG
    Total = 2168 Mi^2PG
    2168 Mi^2PG divided by 32.2 total Mi traveled = 67.35 MPG (notice that Miles cancel and the correct unit MPG is returned.)
    Pretty Freakin Awesome, what?
    Someone check my math?
    RxGATOR and kalome like this.
  5. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Cool! Thank you.
    67.33 MPG rounded, right?
  6. ken1784
    ken1784 SuperMID designer
    2,943
    1,383
    67
    Yokohama, JAPAN
    Column 1
    0 [tr][th]route[/th][th]mpg[/th][th]miles[/th][th]gallons[/th][th]mpg total[/th][/tr]
    1 [tr][td]1[/td][td]58[/td][td]16.7[/td][td]0.29[/td][td]-[/td][/tr]
    2 [tr][td]2[/td][td]84[/td][td]12.5[/td][td]0.15[/td][td]-[/td][/tr]
    3 [tr][td]3[/td][td]50[/td][td]3.0[/td][td]0.06[/td][td]-[/td][/tr]
    4 [tr][td]total[/td][td]-[/td][td]32.2[/td][td]0.50[/td][td]64.8[/td][/tr]
    Ken@Japan
    Codyroo and kalome like this.
  7. schlem
    schlem Polygeek
    82
    39
    Ballard, C@L
    [edit] seems I screwed it up [\edit]
  8. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    Ah....so markabele was right. :)
    Thanks Ken.
  9. schlem
    schlem Polygeek
    82
    39
    Ballard, C@L
    Quoting-an-embedded-matrix-issues aside...
    Ok, I understand this methodology, but why does my math differ?
  10. ken1784
    2,943
    1,383
    67
    Yokohama, JAPAN
    Let's take another example...
    route-1 50 mpg for 100 miles
    route-2 100 mpg for 100 miles
    your math
    Column 1
    0 [tr][th]route[/th][th]mpg[/th][th]miles[/th][th]m^2pg[/th][th]mpg total[/th][/tr]
    1 [tr][td]1[/td][td]50[/td][td]100[/td][td]5000[/td][td]-[/td][/tr]
    2 [tr][td]2[/td][td]100[/td][td]100[/td][td]10000[/td][td]-[/td][/tr]
    3 [tr][td]total[/td][td]-[/td][td]200[/td][td]15000[/td][td]75[/td][/tr]
    my math
    Column 1
    1 [tr][td]1[/td][td]50[/td][td]100[/td][td]2[/td][td]-[/td][/tr]
    2 [tr][td]2[/td][td]100[/td][td]100[/td][td]1[/td][td]-[/td][/tr]
    3 [tr][td]total[/td][td]-[/td][td]200[/td][td]3[/td][td]66.7[/td][/tr]
    I believe my math is correct.
    Ken@Japan
  11. Adam Leibovitch
    498
    102
    Edit: Oh nevermind, just see what Ken said
  12. schlem
    schlem Polygeek
    82
    39
    Ballard, C@L
    Your math is the better, elegant, and obvious solution. I'll take my head-scratching offline for now.
    I sit at your feet.
  13. Adam Leibovitch
    498
    102
    Is it like saying that since you drive to work at 20mph and drive home at 30mph, you average 25 mph for the trip, but thats not right because you used more time to get to work at 20mph, so your average speed is lower than 50/50? Just like OP uses more gallons at a lower mpg's?
  14. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    The simple answer is that you can't average averages to get the correct average. (you will not get the correct answer if you average 2 means).
    Adam Leibovitch and schlem like this.
