Help... I left my interior lights on!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Misty fog, Nov 5, 2012.
  1. Misty fog
    Misty fog Junior Member
    25
    Malaysia
    Left it on overnight, around 10 hours. Did I just screw up my traction battery? When I started the car again I saw 3 bars. Then the engine started running, I left it idle to run awhile. After a couple minutes it stopped, then after a couple of minutes the engine ran again... this repeated twice and then the SOC was almost at 8-9 bars!
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    First the good news, you did no damage to the traction battery, it is completely disconnected when the car is not READY.
    Once you start the car, it will begin recharging the 12 volt battery, which has been powering the inside lights.
    Misty fog likes this.
  3. etobia
    etobia Member
    116
    NEW YORK STATE
    You have basically reduced the battery strength and the gas engine is recharging it. Your mileage will reduce because of this, but as you state, the bars return to 8-9, so the engne has done it's job. Question: Have you returned the overhead light function to power off? :) No, i don't think you screwed up your traction battery......you merely restored it.
  4. sooperedd
    sooperedd Junior Member
    48
    Colorado
    Left mine on the first night after buying it. Didn't harm anything. Your Prius has a 12v AGM battery that can be drained much deeper than a typical Lead Acid. Don't even worry about it.
  5. Misty fog
    25
    Malaysia
    OK, have been pretty careful about taking care of my Prius that I got quite upset about this incident. Feel much better now knowing no harm's done, thanks!
  6. lopgok
    lopgok Member
    177
    30
    unknown
    If you use led interior lights, the power drain will be about 5 times less...
    They are dirt cheap, and brighter than the lightbulbs and should never need to be replaced.
  7. Mendel Leisk
    41,898
    Your 12 Volt battery has taken a hit. You were lucky: an interior light left on overnight can kill a battery, unfortunately. Or put it near-dead. Don't just rely on assurances, see for yourself:
    Get a half-decent ($30~40 range) digital multimeter, and check the voltage to get a more complete picture of what your battery's health is. If it's 100% you'll get a reading around 12.7 volts or higher. Under 12.6 and it's likely taken some damage.
    You can do the voltage check under the hood, at the jumper location. It's in the underhood fuse box, check in the manual. Red lead to the jumper terminal, then black lead to a bare metal bolt or bracket on the car body or engine.
    An "intelligent" charger is worthwhile, for events like this, and just for periodic maintenance. My pref. is CTEK 3300, but it's kind of pricey, there are lots of choices. It will likely take an overnight charging session. The CTEK has indicator lights to indicate when it's still charging (amber), and when it's satisfied the battery is fine and fully charged (green).
    Another item to consider is a portable jump starter, for emergency use with dead battery.
    The hybrids tend to have diminutive 12 volt batteries, and an inadvertant light left on can kill them. Cheap insurance is to turn completely off as many of the "convenience" lights as you can, if you're ok with that.
  8. Misty fog
    25
    Malaysia
    I only left one side of the front interior light on overnight, and it seems everything is back to normal after the incident. No MPG hit or any malfunctions. Going to monitor the situation for awhile, probably get the service center to look at it once its time for the next checkup - not too good with self maintenance!
    Now, this might not be related, but yesterday I got the refuel alert (down to 1 bar). After driving for about 10km or so, I suddenly realized that the distance to empty is now zero! Fortunately the SOC was quite high, more than enough for me to make it to the gas station. I put in around 40.1 litres. I usually pumped at around 38.5 litres, was I really running on empty? Any chance the late refuel alert might be related to the battery drain on my 12v battery last week?
