car auto-locks?
Discussion in 'Prius c Main Forum' started by james cook, Nov 10, 2012.
  1. james cook
    james cook Member
    145
    36
    Louisiana
    2025 Prius
    I notice if my car is sitting for about a minute it autolocks.
    I'm in the great white north....If I leave my car running and the doors lock while I'm not in it can I use my other key to open the car?
  2. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    I do know the car will lock if you unlock it and won't reach it in time. My c does it so does our Kia Borrego. However if the car is running I doubt it will let you lock the doors even manually. If it does let you do that then you could use the key to get in. Even when I had my 1999 Jimmy it would not let lock the door with the key in it while started.
