Seat Heater Q
Discussion in 'Prius c Main Forum' started by Fiddlesticks, Nov 9, 2012.
  1. Fiddlesticks
    Fiddlesticks Junior Member
    51
    Atlanta, GA
    For those with seat heaters: Is the one setting too hot, warm or not worth it?
    I've had a few cars with seat heaters but normally more than one setting. Some on high would burn off your buns!
    Just want to be sure if it is only one that it doest the job properly.
  2. drysider
    drysider Active Member
    823
    335
    Liberty Lake WA
    Mine is a burn-your-butt heater. I turn it off after a minute or so.
  3. JLee81
    JLee81 Junior Member
    56
    Maryland
    They cycle off and on but still get a bit too warm at times.
    SGH-T989 ? 2
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    As with Goldilocks, sometimes it's too hot, sometimes it's too cold, and sometimes it's just right. There isn't an adjustable thermostat so if you don't like it, turn it off.
  5. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    Frankly, it is a bit too early to be using heated seats. Once it gets to zero degrees F, you can judge whether the heated seats are too hot. I just got my C4, but thankfully it has not been cold enough to use the heated seats.
  6. ChinchillaGirl
    ChinchillaGirl OrcaCar
    157
    72
    SJ/SC Commuter
    Okay, maybe I am spoiling myself- in California, its getting cooler and damp (in the 40s) and I like keeping my zaftig tush toasty. I am very happy with the level of heat and have not noticed that it is too warm, but maybe it is partly a function of the padding you already have?
    JLee81 likes this.
  7. JLee81
    56
    Maryland
    I'm seriously lacking in the padding department, lol.
    SGH-T989 ? 2
  8. Fiddlesticks
    51
    Atlanta, GA
    They work great when your back is a bit sore too. :)
  9. MNBud
    MNBud Junior Member
    48
    suberb of Minneapolis MN.
    Maybe I haven't used mine enough,they were installed after I purchased my car by the dealer but I believe mine have two settings, is this not correct? Mine has a rocker switch and I believe down is low,center is off and up is high.
  10. vernon birdman
    vernon birdman Active Member
    330
    141
    Vernon BC Canada
    I have just begun using it as temps have fallen a bit below freezing in the last few days. I have no complaints. It heats up quite fast and seems to heat the lower back as we'll as my tush. It seems to cycle on and off.
    Fiddlesticks likes this.
  11. Fiddlesticks
    51
    Atlanta, GA
    Sounds like you have a different system ?? All I've been able to find out about the factory one is that is is on/off . I haven't seen a car with them yet though.
  12. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    That is interesting. Did not realize the factory heaters only had one setting. My wife uses her's a lot. It is not just a cold day thing with her. Fortunately we have two settings. The low is just right for an ailing back. Aftermarket leather in our car.
    Dan
  13. Fiddlesticks
    51
    Atlanta, GA
    Bummer - I prefer the high/low like you have! I guess it was a cost thing?
  14. vernon birdman
    330
    141
    Vernon BC Canada
    I have the factory installed warmers. It is a simple on/off switch. One for each of the front seats.
  15. crebble
    crebble Member
    176
    47
    Shohola PA
    I would say that these are about the weakest seat heaters I've ever owned. I have never gotten too hot, and my wife rides with hers on all the time. I timed it: 8-9 minutes between heating cycles. Probably a liability issue. Don't want anyone torching their tuchas and lawyering up.
  16. Fiddlesticks
    51
    Atlanta, GA
    Wonder if you could upgrade to a diff system?
    I use mine a lot too. I haven't been able to test a car with it installed.
  17. Webbie
    Webbie New Member
    Houston, Texas
    Mine get warm but not overwhelming. Will be nice when the temps dip colder1
  18. dick_larimore
    162
    70
    Central Indiana
    The OEM seat heaters in my Prius C4 feel like they do not cycle on and off via a thermostat. But in my opinion that is OK. These heaters get your rear warm in no time and I say this based on leaving the car outside and overnight in 5 degree weather. Once your rear is up to temp, you shut if off -- there is no need for temperature cycling.
  19. Gcoop
    Gcoop Member
    156
    79
    niagara region ontario canada
    It was -25 and -22 out the last 2 mornings..
    the seat heaters are sooooo wonderful!!!!!! lol
    ones i had in my old acura were a little hotter,
    but the ones in the priusc are nice.
