Removing wax off black plastic
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tideland Prius, Jan 14, 2006.
  1. Tideland Prius
    16,544
    I got some wax on the black plastic bit at the base of the windshield and the SKS lock button. How do I remove it? It's to the point where it looks like I had white paint splashed onto the black plastic.
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Well I've done the same thing but it never turned white as yours did. Different kind of wax maybe? I have read here that some kinds of dish soap, Dawn is one I think, will remove wax. If that doesn't work you might try something which would be a solvent like WD-40, then wash the WD-40 off with soap and water. Did you read the wax container and see if they offer any suggestions? you might even see if the wax company has a web site and email them for advice.
  3. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Peanut butter.
    I kid you not, its like the only thing that works.
  4. roach52osu
    roach52osu New Member
    200
    Dublin, Oh
    I have used dawn dishwashing liquid in the past but works best when you get it off right away... The penut butter thing I have never heard but interesting and probably worth a try, I hate wax on plastic.
  5. Tideland Prius
    16,544
    I was using Mothers Paste Carnuaba wax. I usually use Turtle Liquid wax but decided to try paste wax since people say it lasts longer Turtle wax...
    Anyway, yeah it's as if I used a paint brush and painted that black plastic piece with white paint. Fingernail will not scrap anything off.
    I'll try the peanut butter method since I have some at home.
  6. Kiloran
    Kiloran New Member
    1,225
    Mineral spirits or turpentine will dissolve wax almost immediately, also kerosene.
    Prelude Cleaner is about $6.
  7. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    Peanut Butter does fine. (Creamy not Chunky :p )
    It also removes chewing gum from hair. It's truely a miracle cleaner.
  8. Kiloran
    Kiloran New Member
    1,225
    Wouldn't peanut oil work just as well with less of its own cleanup necessitated or is the peanut paste needed as an abrasive?
  9. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    Any auto store with a decent selection of car care products should have something for removing excess dried on wax from trim parts. From Griot's Garage (on-line), you can get a product called "Dried On Wax Remover" and someone else makes one called "Black Again". I've have used both and they work fine.
    - Tom
  10. Tideland Prius
    16,544
    You're a genius! I tried peanut butter (yeah yeah, it's creamy Tempus lol) and voila! the white mark disappeared.
    Thanks!
    Edit: Works on road tar on the paint too!
