Rear ichiba spacer installed
Discussion in 'Gen 3 Prius Accessories and Modifications' started by racerx91354, Nov 7, 2012.
  1. racerx91354
    racerx91354 Member
    71
    28
    Had some free time today and was tired of the rear wheel looking like it sunken in compared to the front.
    Ichiba part number WS-5510054G
    Cost 128 shipped through amazon
    Install took about 15 min
    Happy with results.
    ++FRONT NOT NEEDED++
    Before:
    After:
    Others:
    Some pics washed out to change
    mnml and sfv41901 like this.
  2. xliderider
    xliderider Senior Member
    8,035
    3,211
    Honolulu, HI
    Looks good. These adapters are hubcentric?
  3. racerx91354
    racerx91354 Member
    71
    28
    Thanks, yes the adapters are indeed hubcentric
  4. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Nice. Any noticeable difference in ur mpg?
  5. allen2oo3
    allen2oo3 Junior Member
    44
    Orange County, CA
    Looks great. Could you tell me about your wheel center caps? ...need some for mine.
  6. racerx91354
    racerx91354 Member
    71
    28
    I dont think it will affect mpg since actual wheel size/ contact patch has not changed
  7. racerx91354
    racerx91354 Member
    71
    28
    home depot or lowes carries them, 1 1/2 size, just paint and install, they can be found where the electrically boxes are, they are the cut outs for them, there is a thread on how to diy
  8. allen2oo3
    44
    Orange County, CA
    thanks, will search for the thread. do you happen to know the paint you got off the top of your head?
  9. racerx91354
    racerx91354 Member
    71
    28
    I got a krylon glossy black, did 4-5 coats
  10. allen2oo3
    44
    Orange County, CA
    Thanks for the info. Your car looks great.
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Toyota sinks the wheels in to help improve MPGs cause there's less drag across the wheels. I doubt it will be a big difference but if u notice any Change pls post up the info
  12. Texas-Prius
    Texas-Prius One more Prius to fight terrorism
    79
    32
    Austin, TX
    Looks nice. With a now wider track, have you noticed any difference in handling?
    - TP
  13. racerx91354
    racerx91354 Member
    71
    28
    definitely notice the fwd understeer more, only because I can go around the twisties a little bit faster, car does feel more stable with the wider track.
    as for mpg, I went to the doctor today, ventura to hollywood, no difference and handled great in the rain
    Tracksyde likes this.
  14. 714guy
    714guy Junior Member
    22
    Hi did the stock lugs stick out of the spacer at all? did you modify the lugs at all?
    thanks
  15. racerx91354
    racerx91354 Member
    71
    28
    no modification needed. took rear wheel off, install hubcentric spacer with supplied bolts (make sure to torque), install wheel to spacer with stock lugs
  16. 714guy
    22
    thanks!! been wanted to get the spacers but wanted to make sure they fit without modifications.
  17. PriBlack
    PriBlack Junior Member
    Is your car lowered?
  18. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    It will be interesting to see if this affects the life of the wheel bearings that is not that good anyway. They do look good but I'm afraid would be illegal in the UK because the tyre is not covered by the arches.
    catnfriends likes this.
  19. jmrmotorhead
    jmrmotorhead Junior Member
    85
    44
    New Hampshire
    Looks awesome!
    britprius- Lots of people run spacers with no negative effects, should be good to go!
  20. racerx91354
    racerx91354 Member
    71
    28
    car is lowered on eibach springs
