2006 Prius - Steering Wheel Button Issues / Radio knob issues
Discussion in 'Gen 2 Prius Main Forum' started by rhfritz, Nov 14, 2012.
  1. rhfritz
    rhfritz Junior Member
    33
    2018 Prius Prime
    A few years ago the volume control knob on the stock JBL radio began to respond intermittently, e.g. twisting the knob might change the volume level 1 or 2 "clicks" per full rotation of the knob. I had no idea how to fix it, so I started using the steering wheel buttons which I had mostly ignored.
    But now the steering wheel buttons are starting to fail. The climate "recirculate" and defrost buttons no longer work. If the volume control buttons fail, that'll be an issue.
    Has anyone had any experience with these issues and/or have recommendations on how to fix?
  2. northwichita
    481
    102
    29
    Wichita KS
    rhfritz likes this.
  3. rhfritz
    33
    2018 Prius Prime
    Thank you very much. Following those two links gave me exactly what I needed. The radio problem is very well known and can be solved for about $100 on eBay. The Spiral Cable a.k.a. Clock Spring cable can be solved for about $65 on eBay. Now to find the time to actually do it. But I've also been eyeing the new plug-in model ...
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Volume Gone Wild (and then stops working) | PriusChat was another thread on this. I also have the problem w/the volume knob on my JBL stereo either going crazy or not working. A push on the left side of the faceplate "fixes" it.
    I'm a bit disappointed by whoever supplies radios and MFDs to Toyota. I had a stock radio on my 91 Camry totally die. It let out a bad smell before it quit. It was from Fujitsu Ten.
    OP, do you have an 06 AND '10 Prius?
  5. daveatm14
    daveatm14 Junior Member
    Midwest
    I had the problem of the recirculate button on the steering wheel not working when the wheels were straight. If I turned the steering wheel 90 degrees the recirculate button would work. It was the spiral cable. Purchased a new part from eBay. Easy repair if you have a steering wheel puller and the correct size and thread pitch of bolts. You should be able to disconnect the negative battery cable by removing the battery access cover without pulling the entire cargo area floor and storage compartment. I was 1 spline tooth off putting the steering wheel back on but when I got an alignment and tires the next month the alignment fixed the 1 tooth off problem. Good luck on finding time, that will probably be the hard part.
  6. rhfritz
    33
    2018 Prius Prime
    Thanks, I'll see if pushing on the faceplate works. One thing I did try related to the idea that the knob internal contacts needed cleaning was that I had noticed that if I spun the knob for a long time, it improved for a while. So I got my cordless drill, removed the bit, and put a round knot of masking tape on the end. Then I held the tape end to the button where it "stuck" and then used the drill to spin the knob for a while.
    And, yes, we have two Prius' (Prii?). And I agree with your disappointment with the MFD supplier. With my 2010 I discovered that it would refuse to play certain mp3 files. A little digging and I discovered that it only refused to play mp3's which had cover art in the file which was over 256kb. Mind you the player does not display the cover art on the MFD. Regardless, I had to find a tool which enabled me to delete the art from the mp3 and then they played fine. In short, my MFD needs a firmware update.
