Heater Box?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pfdman, Nov 14, 2012.
  1. pfdman
    pfdman New Member
    I have no heat or defrost. Dealer suggests heater box needs replaced. Because entire dash needs to be removed, the replacement estimate comes in over $3700. I think this is insane for a heater. Has anyone else experienced similar problems and/or have suggestions for re-gaining heat?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Suggests? Get another opinion.
    What area are you in?
  3. pfdman
    pfdman New Member
    Toyota Corporate also suggested to get another opinion, however this was from the dealer. Wouldn't they know how to fix the car? Who should I get second opinion from, Honda? or are they acknowledging their dealer either doesn't know what they are doing or they are inflating the estimate? Anyway, I am in the Atlanta area.
  4. gliderman
    gliderman Active Member
    751
    225
    Looks like the dealer is taking the shotgun approach, replace it all. Go to another dealer. Ask the dealer why it is not working and what parts are keeping it from working. You have to be proactive. You dont give enough information. What were they going to replace with the $3700? There arent $3700 worth of broken parts and labor in the heating system.
  5. bisco
    51,843
    no, the dealer can make mistakes, just like a doctor. get a second opinion from another dealer and also from a radiator repair shop. how many miles? warranty is 36,000 i believe.
  6. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    There are some bad dealers. Try another Toyota dealer, preferably one w/no affiliation (e.g. ownership) w/the one you went to.
    BTW, it'd help to update your location info so we don't need to ask again in other threads/posts.
  7. El Dobro
    El Dobro A Member
    7,088
    3,270
    My guess is that it's either an actuator or a control module. Does the fan work?
