What tire pressures are you running?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by eric smith, Nov 18, 2012.
  1. eric smith
    eric smith Junior Member
    44
    DC/Maryland
    I just checked my tire pressure for the first time and was surprised to find them at 30 psi from the dealer. I want to run them high so I brought them up to 42 psi. Is this to high?
  2. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Michelin Energy Saver AS size 195x65x15, all four are inflated to 44 psi
    which is max pressure as listed on the sidewall of the tire.
    This is my second set. My first set I got nearly 70,000 miles and the wear was
    perfectly even on all four tires.
  3. Adam Leibovitch
    498
    102
    35 and 33 because the dealer just deflated them for me in their "world-class multipoint wtv".
  4. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    41 / 39 here.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  6. bisco
    51,787
    39f/37r. you're not too high, but you might want a 2psi differential like factory spec.
  7. eric smith
    44
    DC/Maryland
    thanks, I will drop the rears to 40 and see how that works out.
  8. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    PriusKitty,
    Why did you buy the expensive 120 vac model?
    There are a number of less expensive 12 vdc models, like this one.
    Amazon also has
    250psi Portable Air Compressor Automotive 12V Tools
    by AirHeadTools
    2.5 out of 5 stars See all reviews (8 customer reviews) |
    Price: $12.77
    o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o o
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    because the 12 volt models overload the accessory outlet or melt the 12 volt adapter. I read the reviews from some of the 12 volt compressors
  10. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    also read some of the 12 volt models fail to completely inflate the tire
  11. ukr2
    ukr2 Senior Member
    1,010
    275
    31
    Victor, NY
    The fuse for the PIP 12 vdc power outlets are 15 amp. I can't find the amps of the 12 vdc compressor, but since it's made for a car, I wouldn't think it would exceed it.
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  13. lensovet
    2,615
    496
    Burlington, NJ
    is that true? because the sticker on the outlet door say max 120 W, which would imply just 10 A.
  14. Rainking
    Rainking Member
    164
    New York
    42/40 bridgestone ecopia ep422
  15. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    42/40 here, Yokohamas
  16. Frank Perkins
    Frank Perkins Member
    129
    66
    Fairfield, Connecticut
    Is there a document/xls which maps higher tire pressure to more MPGs? It doesn't look like higher MPG affects tire performance, just comfort?
    Update: OMG, I just checked and my tires were at 25! I just pumped them up to 42/40 which sounded like a good number based on other responses here.
  17. Frank Perkins
    129
    66
    Inflated 3 of our my 4 tires. The fourth tire blew the accessory fuse. Tried the other cig lighter port and blew that fuse as well. I guess I have to order a few fuses... any recos on getting 15a fuses online?
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I rest my case:D
    lensovet likes this.
  19. lensovet
    2,615
    496
    Burlington, NJ
    amazon if you have prime? i bought these for my Accord a year ago but I'm not sure if the PiP uses the same fuse type: Amazon.com: Bussmann BP/ATC15 Carded Fuse: Automotive
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
