finding electrical shorts and more
Discussion in 'Gen 2 Prius Technical Discussion' started by elec1, Feb 20, 2012.
  1. elec1
    elec1 Junior Member
    pa
    Save your money on the scanner its a joke, at least they refunded me my money, What is Zero point Calibration? And how is it done?
  2. Albalawi
    Albalawi New Member
    Usa
    Four Touring
    Hello i am having same problem. Which. Ground wire ?
  3. bisco
    52,263
    probably the neg to ground from the 12v
  4. Albalawi
    Albalawi New Member
    Usa
    Four Touring
    I am having same problem i keep getting o2 sensors codes. Throttle doesn’t work at all i want to know about this connector if there is any cut or its just normal one wire
  5. Pd30242
    Pd30242 Junior Member
    26
    Chicago
    all the information you could ever want is in the wiring diagram
  6. bisco
    52,263
    looks like a lot of corrosion in that connector?
  7. Albalawi
    Albalawi New Member
    Usa
    Four Touring
    I dont even know what’s wrong with my prius. I only gets o2 sensors codes. I changed both I changed sparks coils. Alot of things. And throttle always closed. Doesn’t open at all.
