Aux power outlet
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by rchaput, Sep 15, 2012.
  1. rchaput
    rchaput Junior Member
    24
    I want to purchase a portable 12v air compressor to inflate a tire after having repaired it with a "plug"
    What is the maximum amperage for the compressor? Someone in the forum said 10a. Someone else stated that the circuit had a 15a fuse.
    Any recommendation for a compressor?
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  4. John H
    John H Senior Member
    2,208
    558
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  6. rchaput
    24
    Follow up question. Slime has a 12v. portable tire inflator that uses 11.0 amps. Am I pushing it to use a device that the 'maximum draw' is 11.0 A? What would be the worst case: pop a fuse?
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  10. lensovet
    2,614
    496
    Burlington, NJ
    In another thread we discussed this. The fuse powering the outlet is rated for 15A.
  11. John H
    2,208
    558
  12. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    So is this all about addressing the "no spare" issue? What is the preferred action? Tubeless plug? Slime? and then re-inflate. I'm embarrassed to admit it but I put 85K on my '08 and never opened the hood. Used to be a gear head. Toyota has made me lay and my skill have atrophied. Where is the battery? I think the last tire I changed was in "84.
  13. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  14. John H
    2,208
    558
    This particular model isn't well suited for jump starting a V8, but for energizing the Prius computer and re-engaging the HV battery it should be more than adequate.
    I was mainly trying to find something representative of a combo 12V emergency battery, tire inflator, and inverter that could be continuously maintained in the vehicle using the 12V outlet. Several of these units allow the 12V connection to be bi-directional, using a switch. That feature allows you to easily recover from a dead/low 12V battery in the Prius, providing enough juice to engage the HV battery and start the car.
    The 140watt inverter supports powering most laptops.
  15. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Yes. If you look at the power outlet cover, it says 12V/120W, which means it is designed for 10A.
    I believe that allows it to handle larger, but shorter duration transient currents such as when a device is turned on.
