B Gear
Discussion in 'Newbie Forum' started by johan314, Nov 20, 2012.
  1. johan314
    johan314 New Member
    I accidentally drove my 2008 Prius at B Gear at freeway speeds for a few minutes. I noticed it after the burning tire kind of smell and switched to D right away. The car seems to be driving fine now, but is it possible that I damaged something?
    Thanks
    Johan
  2. CAlbertson
    CAlbertson Member
    99
    24
    It is not really a low gear. It is just an input to the computer. It is perfectly OK to drive at 60 MPH with the "B" setting. That is within the range of intended usage. I use it sometimes on some steep hills at highway speed.
  3. Tideland Prius
    16,621
    There shouldn't be a burning smell but as far as we know, it's just an electronic position to tell the computers to put the engine in a more aggressive engine braking state (so when you lift off, you'll feel more drag as the engine pumps the pistons, just like you would if you were in a lower gear in a regular car).
  4. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    Coming down NC mountain hills, I'm often in B at 70mph (was today!) - no harm done, no worries. Enjoy!
    BlackBerry 9930 ?
