Do you run fog lights all the time (factory or aftermarket)
Discussion in 'Gen 3 Prius Main Forum' started by Jonny Zero, Nov 22, 2012.
  1. Yes, I run them any time the low beams are on, as a cosmetic toy
    13.5%
  2. Yes, I run them any time the low beams are on, to supplement the low beams
    18.9%
  3. No, I only run them in foul weather
    35.1%
  4. No, not ever, they are useless for seeing
    8.1%
  5. No, not ever, the extra power use will drop my MPGs.
    5.4%
  6. I don't have fog lamps on my Prius.
    18.9%
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Just curious. I think mine are good as a cosmetic toy only. I leave them off.
  2. DoPeY5007
    DoPeY5007 Member
    122
    17
    My option is not there. I run them in weather conditions. Stock Prius C4
  3. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Shouldn't that be option 3? The No is for No, not running all the time.
  4. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Installed OEM foglights on our level 3. Currently, I am running them all the time, even when the low beams are off (daytime). Using them as DRLs, which the 2010 -2011 model years do not have. See my signature for details.
    At night, they also visibly increase the illumination directly in front of the vehicle, especially in bad weather (yellow bulbs).
    I am currently looking into rewiring the high beams for use as DRLs at half power, like other Toyota vehicles. They will have a low/high beam override that will either shut them off (low beam) or make them full power when the high beams are switched on or flashed. However, I am worried that this will cause warranty problems.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    I have my on when the lights auto turn on. The 3k bulbs help out & night & look cool.
  6. striker308
    striker308 Three time Prius owner
    302
    43
    Evans, NY (USA) / South Williamsport, PA (USA)
    installed mine with a 55W 3000K HID kit so I only use them when I really need them. combined with the 55W 6000K HID low beams they are a bit much for daily driving for oncoming traffic.
    sdtundra likes this.
  7. Tideland Prius
    16,563
    I would vote 3 but I also use them in low light conditions to supplement the DRLs (high beam at reduced output). Yes I know I could use the full headlights but it's still the middle of the day and sunny unless the sun glare is really bad then I'll use the low beams so that oncoming traffic can see me. Besides, it looks cool with the parking light on top of the DRLs with the fogs on. A unique combination.
  8. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    I'm in the same boat as striker308. 35w 6000k low, 35w 3000k foglights and 35w green high. When I turn the fogs on they look like they shine higher than the lows but i haven't touched them at all. Must be the lack of projector housing.
  9. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I have stock fogs & think they are useless. However, they are switched "on" because I paid for them so I'm using them.
    sfv41901 and striker308 like this.
  10. striker308
    302
    43
    They let you run GREEN in CA?
  11. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    No....it's illegal but that doesn't mean u cant
    WE0H likes this.
  12. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Why green?
  13. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    sdtundra would have to answer that
  14. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Doh!
    WE0H and sfv41901 like this.
  15. Mendel Leisk
    41,609
    I wish there was another option in between "only in foul weather" and the "no, not evers...". I went with the first "no, not ever.." but it's not really a fit: I'd like to say something like "maybe, of limited value...".
    Our Canadian Touring Model has the fogs, and mostly yes, they're just a cosmetic toy. Besides fog, I though they'd be handy on on unlit narrow back roads. We have one situation like that, I'll flick them on, and I'll be damned if I can see any difference. I'll end up turning them on/off a few times just to make sure something's happening, but they're pretty subtle...
    I've driven a Honda Pilot with fogs once or twice, and they were much more effective, in comparison.
  16. mnml
    mnml Ain't nobody got time for that.
    377
    161
    Ladera Ranch, CA
    I run mine with the headlights (auto). Mi Prii look sexier with the fogs on.
    WE0H likes this.
  17. Tideland Prius
    16,563
    I agree. My smart fortwo's foglights were better and I could see the difference (the curb was actually illuminated and the beam was low and wide). The Gen 3's are slightly better than the Gen 2's as they do point somewhat to the side of the car. The Gen 2's were purely cosmetic and were prone to cracking from the intense heat of the bulb.
  18. striker308
    302
    43
    Try these in your fogs........... you WILL notice a change for sure.
    Toyota Prius HID Xenon Fog Light Kit
    use the 3000K and you will see the sides of the road and the road just infront of the car (where your headlights seem to mis) turn a yellow glow.
  19. sdtundra
    1,314
    193
    Sacramento, CA
    It's just for the holidays. Green on a red car with a wreath on the front. Normally the brights are also 6000k but I rarely have to use them anyway
    WE0H likes this.
  20. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Mod note: I've added an additional option for those of us who don't have fog lamps, but want to see the poll results.
    On my 2nd gen, I ran them all the time, but the effectiveness was minimal, so it was more cosmetic than effective.
    WE0H and Jonny Zero like this.
