For Sale Toyota Prius rims with snow tires; nice set of winter wheels
Discussion in 'Private Sales' started by leogsx97, Nov 25, 2012.
  1. leogsx97
    leogsx97 Junior Member
    22
    The wheels are in good condition straight with no cracks. They do have some minor clear coat peeling. The tires are Michelin like new with 10k miles on them.
    The wheels are from 2nd Gen Prius and have sensors in them
    The wheels and sensors are aftermarket from Tirerack.
    Elbrus I05
    Offset: +38mm
    Backspacing: 5.23"
    Bolt Pattern: 5-100
    Tire Size: 185/65-15
    Weight: 16.6lbs.
    Finish: Silver Machined w/Ice Coating
    Tire brand: Michelin Xice
    Tire pressure monitoring sensors, hubcentric rings and nuts are included. $500 firm
    Pick up in Queens NY or will ship (buyer pays shipping cost)
  2. Ahbuhjee
    Ahbuhjee Junior Member
    ssf
    Do you know if these will fit a gen iii?
  3. priuspony
    priuspony Junior Member
    SE PA
  4. F8L
    19,011
    4,080
    Grass Valley, CA.
    They will but the tires are much shorter than the ones on the GenIII so your speedo will be off by 3mph or so and you lose ground clearance.
  5. leogsx97
    22
    As stated by F8L rims size is the same but tires are different. I don't know if sensors are compatible. Please see below for wheel/tire combo for second and third gen Prius respectively.
    Bolt Pattern: 5-100
    Rec. Tire Size:185/65-15
    Bolt Pattern: 5-100
    Rec. Tire Size:195/65-15
  6. leogsx97
    22
    Received request to upload pics of tires.
  7. leogsx97
    22
    I had a request to break up the rims from tires. Anyone interested in just rims/sensors or tires?
  8. leogsx97
    22
    I am back from vacation and responded to all PMs
  9. leogsx97
    22
    Price drop $400 firm
  10. leogsx97
    22
    Still available. Cannot believe that they are not sold yet.
  11. Brian C.
    Brian C. New Member
    Good mooring - are these tires sill avail?
  12. leogsx97
    22
    Yes there are stii available.
  13. Brian C.
    Brian C. New Member
    Thanks. Turns out won't need them after all. Sorry.
  14. zepolska
    zepolska New Member
    Are the tires and rims still available?
