Bad Engine Knock and Very Little Power / Using Lots Of Oil
Discussion in 'Gen 2 Prius Accessories & Modifications' started by ErikH, Nov 26, 2012.
  1. ErikH
    ErikH New Member
    I have been moving recently and I am/was using my Prius to do this. I'm moving about 1000 lbs of stuff per trip, i know this is more than i should be hauling, and I'm driving through the Appalachian mountains. I have 130,000 miles on my Prius and it has been using about 2 quarts of oil every 5000 miles which I thought was high but this last trip I used 7 qts in 2000 miles. Most of the oil was consumed after I got into the mountains on the last trip. At the top of the first big hill I stopped at a rest area and when I started the car back up it was knocking (sounded like a valve knock), as I got back on the interstate the battery ran down very quickly and the car lost most of it's power. I got about 14-15 MPG after that for the next 700 miles. I can't find any info on why the car would do this.
    No oil in coolant and no coolant in oil.
    When oil fill cap is removed I am getting a lot of pressure coming out of the hole.
  2. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    7 quarts in 2000 miles?!?!? Knocking?! :eek: Dear sweet god... I think at that rate, I'd be looking for a hole in the block.
    Have you looked underneath the car for leaks? Any telltale blue smoke out of the exhaust? To go through 7 quarts in 2000 miles you'd absolutely have to be seeing either blue smoke or a puddle underneath. Something is definitely NOT right. You need to get that car safely up on ramps and start by doing an underbody inspection. Is the oil filter tight? oil plug leaking? Crack/hole in the block? I'd be looking for oil on the underbody.
    After that, a compression test is probably in due order.
  3. ErikH
    ErikH New Member
    There is a slight bite of oil residue in the muffler but not enough to drip. It doesn't smoke, at least not bad enough for me to see it from in the car. Some oil under the engine but I attribute that to me spilling oil down the block while trying to fill it on the trip.
    Compression test in the morning but I thought I'd check on here tonight.
  4. wjtracy
    wjtracy Senior Member
    11,371
    3,608
    Northern VA (NoVA)
    ...sounds like something blew.
    Service in order ASAP nearest Toyota or Prius capable mechanic?
    Probably tow it in to save further damage.
    As far as pressure in the oil, is that when car if off or on?
    Keep in mind bad knocking is really pre-detonation - strong explosion, possible mechanical damage to pistons, valves etc. Going up mountains with loads and stuff that's a good day to try Premium octane gaso but I am not suggesting that would have saved the day.
    PS- I will head over the same mountain range tomorrow
  5. richard schumacher
    7,666
    1,047
    United States
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    "Now all of a sudden she started to knockin'
    And down in the dips she started to rockin'
    I looked in my mirror; oh sweet Jesus
    The cops was after my Hot Rod Prius"
    I'm sorry. I couldn't help myself. You may have the 2nd Prius that I remember losing/burning oil. The other one wasn't anywhere close to your amount. It sounds like you managed to destroy an engine. I hope I'm wrong. The Prius is not a good bootlegging car.
  7. ErikH
    ErikH New Member
    The fact that I can tell you that it will/would run 108 will tell you that I may not have driven this Prius the way it was designed.
    I was hoping someone would say, "Oh ya, you just have to change this $20 sensor and it will clear right up!!!"
  8. PriusGuy32
    1,417
    514
    :confused: :LOL:
    Im afraid todays not your day then... and tomorrows not looking good either! lol
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    sounds like ring/piston damage. might be time to look for a new car or a used motor...
