Any idea on curb feelers installation?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by CaliforniaPrius, Nov 24, 2012.
  1. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    found no place to clip on
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    is it really that hard to park? or do you need them to match your chrome mud flaps and wheel spinners?
    the skin of these cars is so thin you'd probably bend something if you did attach that silly stuff.
    if you adjust your rh mirror all the way down, you can probably watch your rear wheel and the curb.
  3. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    This is what I do in a pinch. Honestly, the Prius is one of the easiest cars to park that I've ever owned...
  4. 69shovlhed
    2,170
    752
    Delaware
    ^+1. you might know how to drive... some of these other folks....?
  5. maestro8
    471
    109
    nor cal
    ...not if you asked my lady. She's convinced I'm hell-bent on killing her every time I drive. It's not my fault they put all these nifty banked curves for freeway on-ramps and off-ramps!
  6. CaliforniaPrius
    313
    201
    Alameda, California
    I tend to park very close to curbs, park and go without adjusting mirror back and forth, prius is not like other high end cars with automatic adjustment that kicks in when you shift to reverse
  7. 69shovlhed
    2,170
    752
    Delaware
    since the prius is kinda narrow, you don't need to risk crunching a wheel. give yourself a couple extra inches...
  8. maestro8
    471
    109
    nor cal
    I heard they make pills for that... ZING!
  9. 69shovlhed
    2,170
    752
    Delaware
    did they work for you?
  10. dogfriend
    7,512
    1,190
    Carmichael, CA
    The best way to mount curb feelers is one curb feeler for every 4 sq/in of the body surface including the roof and the hood. Avoid glass areas. May reduce aerodynamic efficiency, but will reduce the chance of traffic collisions by making the vehicle more visible to other drivers. :sneaky:
  11. 69shovlhed
    2,170
    752
    Delaware
    bad dog!
    dogfriend likes this.
