Mileage in Oregon
Discussion in 'Gen 3 Prius Fuel Economy' started by Wognath, Nov 27, 2012.
  1. jaymac
    jaymac membore
    179
    57
    Oregon ( Umpqua Valley )
    2013 Prius v wagon
    My experience has been a direct parallel with the above post. By the way, there is no change in the signage at the gas stations I frequent : they are still tagged " 10% ethanol " What change would constitute a winter formulation ?
    52,286
    winter formulation is often mtbe (google) and reduces mpg's. it was here a long time before the great thinkers in washington decided ethanol was a good idea.
  3. fuzzy1
    10,588
    Winter formulations have been around ever since seasonal runability problems were noticed. Summer blends needed reduced vapor pressure to prevent vapor lock. Now this includes reduced pollution from evaporation. Winter blends needed higher vapor pressure to ease cold starts.
    MTBE and ethanol to reduce air pollution from combustion products came much later.
    The first link in Why mileage gets worse in winter has some more discussion about this.
  4. jaymac
    jaymac membore
    179
    57
    2013 Prius v wagon
    Thanks for the info ! Now I understand that a whole lot better.
