How to charge @office; no outlet :-(
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by fouaddba, Nov 29, 2012.
  1. fouaddba
    fouaddba New Member
    Hi Folks,
    Just bought Plug-In and would like to know, is there any way to charge @office too, because in our parking lot, they don't have a single open outlet, where I can plug it in.
    I was researching for some portable/feasible generator/ups, but still struggling; what I should buy to charge my car to take me back home, as it is just giving 11.3 miles w/out heat and 10.3 or less with heat on.
    Advice/thoughts/suggestions are all welcome.
    Thanks in advance.
    Syed
    51,897
    i hang an extension cord out my office window. if this isn't feasible, you could get a small honda generator and keep it in the hatch.
  3. El Dobro
    El Dobro A Member
    7,088
    3,270
    I would imagine charging the car with a gas generator kinda defeats the purpose of a plug-in.
  4. fouaddba
    fouaddba New Member
    That's why bringing to the team, what are my best options ... what about this honda generator or APC UPS system, do advice/suggestion, as hanging cord is out of the question, because of the size of the complex.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  6. fuzzy1
    10,438
    A portable generator will be more polluting and less energy efficient than simply using the PiP's gasoline engine.
    Short of finding a public charging station within a few blocks of the workplace, or trading for a Leaf or a Volt, I think sticking to gasoline for the trip home is the best bet.
    JMD, JamesCSmith, WE0H and 1 other person like this.
  7. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Get the extension cord, not the generator.
    Installing an outdoor outlet is NOT a big deal. Ask permission and get it installed.
  8. Adam Leibovitch
    498
    102
    Just enjoy the 50mpg's on gasoline. When electricity is not available at a plug, gasoline is the most efficient energy source.
    PriusPlugIn and WE0H like this.
  9. bisco
    51,897
    how far is your commute, one way?
  10. El Dobro
    El Dobro A Member
    7,088
    3,270
    Luckily, I found a 110 socket on the outside of the building where I work. :D
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    sock it to me:D
  12. CaliforniaPrius
    CaliforniaPrius Active Member
    313
    201
    Alameda, California
    buy a generator
  13. 3PriusMike
    3,100
    2,419
    Silicon Valley
    You need to get the robot in this video and a long extension cord.
    Milestone 2 Reached! Now You Can Watch It | Willow Garage
    Mike
  14. bisco
    51,897
    wow, that was cool!
  15. John H
    John H Senior Member
    2,208
    558
    install a solar carport
  16. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Assuming you're not willing to trade it in on a Volt that would actually cover your commute.*
    Ask about paying to have an outlet installed and paying to charge. Even suggest that you'd be happy to have charging limited to the morning so you're not charging near full peak.* Hopefully they'll think about it seriously and you'll set the ball rolling on a structured installation that will enable more people to have plug-ins.
    Until you have a socket available just run on gasoline. If you're a typical commuter your evening commute is warmer than the morning commute so the car will warm up more easily.
    Obviously, don't use a generator. It's worse than running on gas.
    * Heavy workplace charging would just make the peak demand problem worse and lose the potential synergy. I advocate that where possible people buy cars with enough range to cover their entire commute not just half of it. Also, when you do charge during the day at work, try only to charge as much as you need, not as much as you can: unfortunately, manufacturers don't make that easy as they assume you're charging to full.
    John Hatchett likes this.
  17. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Anytime you have to add another piece of equipment (like a generator, APU, etc..) you lose- you cant beat the laws of physics until machines can be 100% efficient.
    Your only viable economically sound options are; plug in or drive home with the ICE. The PIP gets 55mpg+ without any usable charge in the EV battery. Many many people would be extremely happy to get 55mpg, we PIP owners just get used to seeing 80+ mpg and are disappointed to see 55mpg. Sometimes you just have no way to recharge and have to live with it... 55mpg is nothing to complain about.
    Jaimison and Adam Leibovitch like this.
  18. Mendel Leisk
    41,408
    Yes!
    Bringing along an extension cord and looking for an outlet just isn't kosher. It's maybe not a lot, but it does cost something.
    Let your employer know your situation. You may even get free juice. Or have to pay a nominal amount to get an outlet (or multiple outlets) installed, and/or a monthly charge. It's good PR for the company too.
  19. CaliforniaPrius
    313
    201
    Alameda, California
    The reason for someone to buy a plug-in is not because high MPG or what, it might be pure personal inclination or pure environmentalism. Don't think about everyone like an engineer.
  20. essaunders
    essaunders Member
    195
    NH
    I bought a LEAF so I wouldn't worry about charging at work. My commute could be ~14 miles RT, but with some intra-facility driving for my job I can be up to 40 miles for the day.
    But, give you have a PiP, I'd suggest not worrying about it. the Prius engine is a great way to move the car around and certainly beats lugging around a dedicated generator.
    when you get your next car, take a closer look at the real capabilities of the car vs your real needs (and desires).
