Ignition short - 12V drain? Transmission? 12V's charged. No error codes but Pkg Bk is not sensed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by trjd12, Dec 2, 2012.
  1. trjd12
    trjd12 New Member
    Issues:
    1. Getting beeping noise like the keys left in the ignition when the doors open although they are not- battery is good.
    2. Red triangle on start up with warning about Transmission- Parking brake does not sensor as being on, when on - in the diagnostic screen.
    3. Fog lights are no longer operating when just the parking lights are on, but are when the headlights come on.
    These issues may be separate but they all kind of happened in the same time span.
    Background - 2009 Prius, Optium Battery initially installed Spring of 2012, over 66,000 miles. Battery is good, all fuses are good.
    Since installing the Optium Battery I have had to change the battery about four times - as I am not always driving so I keep a 12v battery on the ready on a battery maintainer just incase I need to change batteries - not optimal, but it works for now. For this reason I turn the SKS off.
    Last week my FOB started working erratically for about a week. I would have to press the button several times to get my door to open. Then it started working again like a champ. The battery in the FOB was changed by the dealer in September.
    I regularly use the fog lights without the headlights. At the start of the week the fog lights no longer worked with the parking lights and only with the headlights.
    Later in the week the car started beeping whenever I exited the vehicle from the driver's side. The beep was the constant short beep like when you leave your key in the ignition. I had not and nothing else was on (I read the post about the guy who moved his car for a family function.) This is an issue I associate with me having to change the battery, however it would have to wait to the weekend and an onboard diagnotic indicated that my battery with load was running at 13.9volts. Every other time I would start the engine I would get the red triangle and retry and the car would start up fine.
    I was not able to make it to the weekend to change the battery and had to get a jump to get home on Friday. Upon initial start up after the jump and changing the battery the car indicated that there was a problem with the transmission ... park on flat surface... (Message goes to quicky for me to write it all down and I could not repeat the situation to get the message again).
    Even after changing the battery (new battery is charged and good) I still get the beeping noise like I left the key in. I turned the SKS on and turned the ignition on without the key, turned it off and opened the door and there was no beeping. I repeated this process several times, and after I did this every time it would beep after using the key in the ignition and properly shut down but not when I used the SKS. I have learned this being an issue in non-smart key vehicles where they would either use WD to lubricate or fashion a type of hook to get our whatever was in the ignition.
    Questions:
    1. Have you heard of something causing the ingnition switch to continue to think that it was on in a smart-key ignition switch, and if so, how would I go about finding and removing or remeding the situation without resulting to the SKS. Could this be contributng to my battery drains?
    2. Have you seen - Transmission message - could it be related? Related to parking break not being recongized?
    3. Fog lights - is there a mod that I some how turned off, as they still do not come on after I changed the battery.
    Thank you for any insight!
  2. Patrick Wong
    18,210
    6,513
    Since your reported symptoms 1 and 2 sound like a weak 12V battery, I would suggest that you reconsider your assertion that the installed battery is charged and good. You can measure battery voltage when the Prius is IG-OFF to confirm or refute that assertion. A new AGM battery at 100% charge will measure 12.9V.
    Regarding #3, typically the factory fog lights will not operate unless the headlights are on - unless you implemented a modification to the wiring.
    If you are able to confirm that the installed battery actually has a good charge, I suggest you disconnect the negative cable where it bolts to the body for a few minutes to allow all ECUs to reset. Then reconnect and see if that makes any difference to your symptoms.
    [email protected] likes this.
  3. trjd12
    trjd12 New Member
    Can I assume you are suggesting a voltage meter to measure this?
    Symtom 1 stopped when I turned on the SKS and started the ignition without putting the key in.
  4. Patrick Wong
    18,210
    6,513
    Yes.
    You also might check the tightness of the battery cable connections to the battery as well as the negative cable connection to the body.
  5. rocketrob
    rocketrob Member
    104
    Los Angeles
    Thank you for this thread. I have a 2007 Prius, 65K miles, and a NEW Optium yellow top battery installed in August 2012. The battery appeared to be healthy and functioning normally until ~ 2 weeks ago. Since that time I'm consistently seeing symptom 2:
    This symptom is usually accompanied with 'pulsing' in the brake pedal at startup.
    I've only seen symptom 1 once after presumably draining the 12V battery by powering into Acc-only mode (or whatever comes before 'READY' mode) and using the MFD in Maintenance mode to check the 12V.
    And for the record, my model does not have fog lights, so strike symptom 3 for me.
    I have attempted to charge the 12V battery with long trips of 3 hours or more and even keeping the car in Ready mode in the garage for 4 hours. This temporarily solves the issue, but after a day or so the Red Triangle at startup comes back.
    I have not yet checked the battery connections (thanks for the tip!) or checked fuses.
    I'm wondering what, if any, 12V battery loading might be causing a "vampire draw" while the vehicle is powered off.
  6. Patrick Wong
    18,210
    6,513
    I suggest you consider the most likely possibility, which is that your 12V battery may have failed (regardless of how new it may be or its brand name.) Measure voltage across the battery after the car has been IG-OFF overnight.
    To determine quiescent current draw, you would need to connect a digital multimeter set to read current, in series with the 12V battery negative cable where it connects to the car body. Position the meter so you can read it with the hatch closed. Close the hatch and doors, lock the car, place the fob at least 15 feet away from the car. Then see what the current reading is. If much more than 20 mA (or 0.02A) then you have a problem with excess current draw.
  7. rocketrob
    rocketrob Member
    104
    Los Angeles
    This occurred to me as well. What voltage reading would indicate a failed 12V battery?
    Thanks in advance.
    edit:
    Does a FOB kept within the vicinity of the car drain the 12V?
  8. rocketrob
    rocketrob Member
    104
    Los Angeles
  9. Patrick Wong
    18,210
    6,513
    A new fully-charged AGM battery should measure 12.9V. If the voltage is 12.2V or less then it needs help or replacement.
    Well, it doesn't "drain" the battery but it will result in a much greater current draw. A Smart fob located nearby will be in two-way communication with the Smart system in the Prius. The skid control ECU will run the brake actuator to ensure the brake hydraulic system is pressurized, in preparation for the car being driven. If you want to see what the quiescent current draw is, you should keep the Smart fob well away from the car so that these systems are not provoked to run.
  10. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Patrick I do not know how many different models of the gen2 Prius there are but the UK/EU version does allow use of the fog lights with just side lights may be different in US. To only allow them to work with the headlamps would defeat there purpose and make them useless.
  11. Britprius
    5,194
    1,922
    Checking the US wiring diagram shows the ground return for the fog light relay is controlled by the body ECU at pin 17 so it is not clear how they operate in the US.
  12. richard schumacher
    7,666
    1,047
    United States
    Any further report? It is always helpful to learn how others problems were resolved.
