buzzing
Discussion in 'Prius v Main Forum' started by schinia, Nov 27, 2012.
  1. schinia
    schinia Member
    162
    25
    cape carteret,nc
    we parked the V in the garage at 5 pm, and at 11pm went out into the garage for something, and heard a buzzing, but had a hard time trying to locate the noise. it seemed to be coming from the V. so i opened the drivers door , and after a couple seconds it stopped. then i closed the door and it started again. i opened it a second time it stopped again, after i closed it, it didn't start buzzing again ??? does this happen to other peoples prius's
  2. Alan Stoddart
    Alan Stoddart Junior Member
    27
    Not happening on ours, but we always lock the doors (condo underground parking).
    Maybe it's telling you that the doors aren't locked?
  3. Motoslave
    Motoslave Junior Member
    Atlanta, GA
    It could be this perhaps..
    "The little whirring noise you hear coming out of the hood when you first touch the driver's door handle is the brake fluid pump. Because it's electric, it has to pressurize itself before you get in and step on the brake."
    Read more: A few "v" facts | PriusChat
    DianneWhitmire likes this.
  4. schinia
    schinia Member
    162
    25
    cape carteret,nc
    NO, NO, IT'S NOT COMING FROM UNDER THE HOOD. IT IS NOT A NOTIFICATION BUZZING, AND I NEVER LOCK MY DOORS IN THE GARAGE. I'VE HAD THE CAR 6 MONTHS , AND THIS IS THE FIRST IME IT'S HAPPENED. IT IS A FAINT BUZZING. IT IS COMING FROM THE REAR PART OF THE VEHICLE AS FAR AS I CAN DETERMINE. ALSO THE KEY WAS NOT ON MY PERSON, AND I NEVER TOUCHED THE CAR.
  5. Jzerocsk
    Jzerocsk Member
    108
    31
    I had to dig for this because for some reason it's not listed in the section of the manual that describes the unusual sounds that are unique to the hybrid system, but check this out on page 20:
    PriusInParadise and Chazz8 like this.
  6. Adam H
    Adam H Junior Member
    61
    Yes I heard it a couple of times on my V 3. It is a buzzing sound and goes away after some time.
  7. OWG
    OWG Junior Member
    86
    Barrie, Canada
    I have heard as well, long after the car has been parked in the garage. Just chalked it up to some need of the hybrid system.
