Driver's side window switches not working correctly
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by delrey, Dec 5, 2012.
  1. delrey
    delrey Member
    280
    SF Bay Area (East Bay)
    Hey there, has anyone else encountered this? My driver door window switches have the following problems:
    1. The front driver's side window does not seem to have auto or express up/down. (Works fine for both passenger side windows).
    2. The rear driver's side window doesn't not go up or down at all when using the driver's door switch. The rear door switch operates the window just fine, so it's a switch issue, not a window issue.
    (Probably obvious from the symptoms but I am not talking about accidentally locking the 3 non driver windows & then being confused)
    Any ideas, other than service?
  2. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    no advise, just go to dealer service to document and fix the problem.
  3. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    There should be some kind of window reset procedure. When I replaced a battery in a Honda, the driver side window was acting weird (no auto-up/down, etc). I found there was a reset procedure (I think it had something to do with the pinch protection). After I did that, the window was fine.
    EDIT: Check the manual, page 172
    Here's the text (copy and pasted from PDF)
    When the power window does not close normally
    If the jam protection function is operating abnormally and a window cannot
    be closed, perform the following operations using the power window switch
    on the relevant door.
    ●After stopping the vehicle, the window can be closed by holding the
    power window switch in the one-touch closing position while the
    “POWER” switch is turned to ON mode.
    ●If the window still cannot be closed even by carrying out the operation
    explained above, initialize the function by performing the following procedure.
    Hold the power window switch in the one-touch closing position.
    Continue holding the switch for a further 6 seconds after the window
    has closed.
    Hold the power window switch in the one-touch opening position.
    Continue holding the switch for a further 2 seconds after the window
    has opened completely.
    once again. Continue holding the switch for a further 2 seconds
    after the window has closed.
    If you release the switch while the window is moving, start again from the
    beginning.
    If the window continues to close but then re-open slightly even after performing
    the above procedure correctly, have the vehicle inspected by your Toyota
    dealer.
  4. delrey
    delrey Member
    280
    Awesome!
    I'll give it a try and let you know. Of course I'll take it in to the dealer for service if this doesn't work ... time at the dealer is a pain though so I'm very happy to have found the reset procedure, thanks a million.
  5. delrey
    delrey Member
    280
    Yes!!! Fixed. Happy dance, thank you, thank you, thank you!
  6. wgogle
    wgogle Junior Member
    If the drivers side window still rebounds while trying to reset, open the passanger side window and repertory. This was what finally worked for me.
