Creaking/popping noise from front of car from stop.
Discussion in 'Gen 3 Prius Main Forum' started by Dorian7, Dec 10, 2012.
  1. Dorian7
    Dorian7 Junior Member
    70
    Hi All,
    I am wondering if anyone has had this issue before? I noticed that it started recently and does it consistently... When I accelerate from a stop there is a creaking/popping noise that comes from the front of the car. It is difficult to pinpoint but you can make it do it every time and it only happens from a complete stop. Has anyone else noticed something similar? My '12 only have 6k on it.
    Clix323 likes this.
    52,001
    could a plastic panel be loose/dragging under the car?
  3. Dorian7
    70
    I will take a look. I did recently have the oil changed so maybe I should look over what they did. Do you have to remove any plastic during an oil change?
    What the sound seems like to be is that something "adjusts" during acceleration from the stop. Like maybe the suspension is moving a little, or the axles or breaks. Something kind of "Pops" into place. I'm not sure tho.
  4. bisco
    52,001
    there is a plastic oil change lid that breaks quite often during an oil change. could be something stuck in your wheels/brakes like a branch or something?
  5. Dorian7
    70
    I will take a peek under the car but I haven't been anyplace with it that it would pick anything too crazy up. I guess something could be sliding around in there causing the popping noise.
  6. Former Member 68813
    3,524
    983
    US
    I meant to post about it for a while, but I hear faint fast popping sound when braking to stop below 10MPH or so. And it's not brake pump, but rather sound from suspension or brakes, front passanger.
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    I hear something similar. The main one I hear is while turning at very low speed like pulling out of my driveway. I have heard the noise during acceleration from a stop. Usually in a parking lot.
  8. Dorian7
    70
    Yes, this is what I am experiencing. I guess it's "normal"? I checked it out today and didn't find anything obviously wrong. Like you described it's like something is flexing or adjusting. Sounds really tick me off. Haha. I May have to stop by the dealer to see what they say. I certainly don't remember this being around in the beginning.
    While trying to diagnose the creaking noise I also noticed that when in EV, when you first push on the gas pedal it makes a screeching noise. Do you guys notice this too? It's only obvious with the windows down. But it's kind of a screeching noise (not just the noise maker).
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    I don't notice a screeching noise. I'll listen for it though.
    The popping noise wasn't there when I first got it. I thought it had something to do with my spring install but I'm sure we tightened everything properly.
  10. Dorian7
    70
    Here is a link to the video of the squeaking noise, you will hear it over the "noise maker" as I accelerate. Do you guys have this?
  11. Dorian7
    70
    Do you guys hear this on yours too?
  12. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    i started hearing that after my springs install too ><
    F8L likes this.
  13. ucsmfu
    1,498
    420
    canada
    now, I'm hearing all kind of sounds, every time i drive, so I just crank up the music and pretend that everything is fine :)
    mnml likes this.
  14. Clix323
    Clix323 Junior Member
    Los angeles
    Did u ever find out what was it?
  15. akrca4
    akrca4 Junior Member
    26
    I am getting the similar popping noises. Anyone knows what might be the issue? Thanks!
    Andy
