2012 prius jbl- instaled oem nav everything works but navi sound
Discussion in 'Gen 3 Prius Audio and Electronics' started by vahehs, Dec 9, 2012.
  1. vahehs
    vahehs New Member
    hi everyone,
    i don't know if i am posting to the correct area but i just bought a 2012 Prius 3 with jbl system then i bought the oem navigation unit, installed with the Bluetooth unlock cable, everything works great with the exception of the navigation sound, i can see the route but it says please go to route to begin guidance than nothing when i go to route, no rerouting no sound what so ever, please help as i am pulling my hair out, i don't know what ive done wrong, i also connected the speed wire to the jbl amp under passenger seat to purple wire, please please help
  2. ucsmfu
    ucsmfu Senior Member
    1,498
    420
    canada
    i had the same problem as well, no luck, brought it to Toyota they said the Nav is faulty, so I returned it ><
  3. vahehs
    vahehs New Member
  4. ucsmfu
    1,498
    420
    canada
    did you buy yours from ebay ? if so you are protected and you can get your money plus the original shipping price back !!!
  5. vahehs
    vahehs New Member
  6. vahehs
    vahehs New Member
    ok so i went and got another navigation jbl unit for my 2012 prius and the same problem, everything works except the navi sound, it says go to route so it can start guidance, and i go to it and nothing, please help if anyone knows anything about this issue
  7. vahehs
    vahehs New Member
    some new update in regards the 2012 Prius 3, oem navi install, it looks like the system is ok since i tested 2 units and both the same, so digging a bit deeper found that there is a extension module that is needed, so i am going to get it, will post later
  8. Adam Leibovitch
    498
    102
    Well looks like you found the problem. When I had my amp installed I made sure to use all 6 channels from the head-unit, because I had heard about the speakerphone and navigation using just the front 2 speakers and some people having to return to the installer to get those features functional. Some installation procedures instruct you to run just the front left and right speaker to the amp/dsp, which can cause you to lose features. Just thought I would throw it out there. If this is what happened that would mean that the nav first comes through all speakers but then moves to just the front; sounds unlikely for this, but maybe someone will read this in the future.
    bluetooth phone works?
