How much to buy and install a charging station?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by priusenvious1, Dec 12, 2012.
  1. priusenvious1
    priusenvious1 Member
    325
    37
    LA
    I live in a condo and our garage has concrete walls with no electrical outlets in sight. What would be a reasonable range you think I could expect to pay for a charging station?
  2. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Contact your local electric company to see if they have an electronics contractor that will evaluate and give you an estimate on costs. I contacted DTE in the Detroit area and they supplied a contractor which gave me a free estimate.
  3. priusenvious1
    325
    37
    LA
    I'm already doing this but it's a slow process to get someone to come out and do an estimate. Just wondering if anyone had any experience with this already so I know what to expect.
  4. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    Depends on how far the panel is from the site where you wnat the 240 volt outlet installed in my case they gave me about $1900.00 which included the EVSE
  6. priusenvious1
    325
    37
    LA
    Not bad. LADWP gives a $2K rebate so that would be covered.
  7. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    yeah, true, but in my case, because my outlet would be on commercial property I'm not qualified:cry: :notworthy:, fortunately, the parking spot that I have at my apartment already has a 120 volt outlet.:D
  8. fotomoto
    fotomoto Senior Member
    5,632
    3,810
    So. Texas
    Does it have lights?
  9. Adam Leibovitch
    498
    102
    To get the rebate you not only have to install the charger but also a separate meter. Running a new meter can be expensive as well.
    ryogajyc and lensovet like this.
  10. fjpod
    fjpod Member
    419
    72
    New York
    Do you really need more than a 120 volt outlet with a PiP?
    lensovet likes this.
  11. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    and the separate meter probably not included in the rebate:cry:
  12. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    Not if there is not much on the circuit when the car is charging. I have mine plugged into a regular garage outlet. Works fine.
  13. lensovet
    2,615
    496
    Burlington, NJ
    well the rebate is $2k. if you can do everything under that money – more power to you. but as you mentioned, the EVSE install alone will probably be that much, so the meter wouldn't get covered.
    btw, an option is to just run a 240 V outlet+meter and do an OpenEVSE. then you could potentially fit into the 2k.
  14. priusenvious1
    325
    37
    LA
    How much does metering cost?
  15. lensovet
    2,615
    496
    Burlington, NJ
  16. John H
    John H Senior Member
    2,208
    558
    meters cost in the $25-$40 range but typically they are supplied by the utility company and you pay for them in the monthly utility bill or as part of a "connect fee". my local electrical coop has a monthly base charge of $19 for each account (meter). Your utility will be different.
    watthour electric meter in Test Equipment | eBay
  17. priusenvious1
    325
    37
    LA
    Oh not bad at all then. Wait a one time $40 fee or a monthly fee of that amount?
  18. John H
    2,208
    558
    Don't let the prospect of a $2k rebate for a charging station divert you from the simplicity and lower cost of just installing a 110V outlet in the shared condo garage.
    simply adding a 110V outlet can cost about $150-$250 and a locking cover can easily be added. install the outlet in the least expensive location, and least desirable parking spot, to avoid complaints from other condo owners.
    Thomas Betts Weatherproof Locking Receptacle Cover WTG100 CVL | eBay
    you can calculate how much your charging will cost of a monthly basis and write a check to your condo association to reimburse the electric expense rather than having it separately metered. If your condo's electric rate is $0.11/kWh, write them a $10 check each month.
  19. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    If you buy a charger, go to the post office and get the "new resident" package thing they mail out to all new home owners. It has a Lowes 10% off card in it. You can then drop the priceof the GE Watt station to under 1,000$ after tax.
    If you do not hard wire it then you should not need permitting on it. so that could save you permit fees. Depending how far your service panel is from the charger location you could probably get away without permitiong it also since it will probably be all external conduit since you said the walls are concrete. I believe if it's external mounted and less then XXX outlets it does not require permiting. If you are hard core "Mr. Permit" obviously check on that. I'm pretty anti bull shit permits so I wouldn't permit something like that.
  20. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    OpenEVSE is not UL, so it does not qualify for the LADWP rebate.
    LADWP supplies the meter for free, but it goes into a meter box which you must pay for and wire. The meter box must also be placed where it can be read by LADWP (probably where the existing meters are), which may be far from where you want the EVSE installed. There is also a charge of $8 a month to read each TOU meter/submeter.
    You should call the LADWP EV hotline. There a lot of details and the easiest way to get them is from the EV hotline.
