Warming up the car in winter
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by mikenancy1, Dec 15, 2012.
  1. mxben
    mxben Junior Member
    29
    Quebec, Canada
    2013 Prius Plug-in
    Yes, they asked me if I wanted it and I was a little surprised because this was the first time a dealer asked me this question. Here they usually put it on the car by default and i always thougt that they wouldnt let me buy a car without a block heater.
    52,186
    yes, i wouldn't think many cars would start very well in that kind of weather without one!
  3. mxben
    mxben Junior Member
    29
    Quebec, Canada
    2013 Prius Plug-in
    Here, each year we have a few nights at -40 and you can feel it's really cold and dry. Your nostrils tend to stick but at least it's never winding at these temps. The clutch pedal on my old corolla is taking a lot of time to get back to it's position and the tires freezes in their resting position so when you take the road the car is shaking! :eek:
  4. bisco
    52,186
    wow! the coldest i've seen is around 5 below, no sure i could handle any colder. as it is, i keep dreaming of florida.:p
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    IIIIIIMMMMMM dreaming of a whiiiite xmas:coffee:
  6. retired4999
    2,652
    627
    Eau Claire, Wi.
    Yep! that -40 below snow just has a special crunch to it, doesn't it! :D
  7. bisco
    52,186
    supposed to get 1-2" tonight.
  8. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    4 to 6 on wed for me:D
  9. Drake
    Drake Junior Member
    71
    Quebec, Canada
    2013 Prius Plug-in
    However, I think I saw something about operating temperature in the user manual. If my memory is right, you are not supposed to charge the car below -22°F. (-30°C) Just be cautious about that. It's better to use more gas that day than to harm the batteries.
  10. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    With the plug-in, there hasn't been anything routine to get a metric from. Of course, the inconsistency of winter snow & ice makes that pretty much a meaningless measure anything. However, I did measure an interval of 8 minutes with the 2010 when stuck in a nasty commute home two winters ago.
    Today's driving was more of a "normal" circumstance. I drove to mom's, back home, to work, then home again. The total distance was 45 miles. The resulting average was 63 MPG. Considering that included 3 cold starts (18°F from mom's, 10°F from work) and just a single charge, I'd say that was pretty darn good. The outcome of that same situation with my 2010 would have been about 20 MPG less.
  11. bisco
    52,186
    do you have a block heater john?
  12. john1701a
    12,818
    5,303
    58
    Nope.
  13. bisco
    52,186
    since john does not have a block heater, he cannot answer your question. perhaps someone who does would be willing to do some testing.
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I have a small kitty on my engine, does that count?:whistle:
