Aux vs. disk
Discussion in 'Gen 2 Prius Audio and Electronics' started by kente777, Jan 18, 2006.
  1. kente777
    kente777 New Member
    194
    NW Florida
    Assuming my disc tracks and my Ipod tracks are ripped at a 192 bit rate, which do you think will sound better -- using an Ipod through the AUX jack or either a CD or MP3 disk?
    Thanks.
    Ken
  2. Betelgeuse
    Betelgeuse Active Member
    1,460
    24
    New York, NY, USA
    I think the disk will sound better. I haven't done the test or anything, but it seems to me that the patch cable between the iPod and the jack (not to mention the connection between the jack and the stereo head) would add extra noise. Also, you'd be processing the signal through another amplifier, as well (in the iPod). On the other hand, the difference may be negligible.
  3. Kiloran
    Kiloran New Member
    1,225
    The processing the CD as opposed to the analog signal passing through a cable would certainly have to be better.
    However, how much better and whether a human could detect the difference...
  4. fugsco
    fugsco New Member
    Omaha
    I get a hum from iPod when (I figure) it is reading and caching the rest of the current song, right at the beginning of every new track. This (pretty minor) high-pitched whine lasts about 3 seconds into the currently playing song but after, the audio quality is pretty good. Needless to say, this never happens with CDs or MP3 CD-Rs. I have to agree with the simple logic of added noise, too, from an additional amp (in iPod) and the added wiring (iPod to AUX input, input to stereo head). Fewer inches of wire is always better.
  5. Kiloran
    Kiloran New Member
    1,225
    When using my IPOD Nano in the car, I've never experienced any unexpected/unwanted sound (hum, hiss, etc.) with the exception of an occasional pop if I plug it in with the IPOD on and the radio already set to AUX.
    I avoid the pop by plugging the IPOD in powered down.
    (I use the Nano in the car without a charger.)
    I imagine different model IPODs may exhibit different results.
  6. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    the ipod nano is a "memory stick" so it has no hard drive. I'm sure the hiss is from running the hard drive to cache up new music
  7. Kiloran
    Kiloran New Member
    1,225
    That's what I figured.
    So it's not noise from/through the AUX port and cable but simply the operating noise of the hard drive of the IPOD.
    I imagine that closing the IPOD inside the armrest would reduce its noise considerably.
