Advice on hiding key solution while surfing
Discussion in 'Gen 3 Prius Main Forum' started by Simsonic, Dec 30, 2012.
  1. Simsonic
    Simsonic Junior Member
    I surf three to five times a week and I can't take my key fob with me in the water. Does anyone have advice on what I can do? Is there a hide a key solution?
    51,851
    wrap it in tin foil and put it in the back of the car. take the metal key with you.
    sfv41901 likes this.
  3. DoPeY5007
    DoPeY5007 Member
    122
    17
    If it is a smart key, I don't think any hide-a-key will work as the key will always be close enough for someone to open the door. Have you thought about some sort of water proof pocket?
    Found these with a quick search Waterproof Pouches
  4. gliderman
    gliderman Active Member
    751
    225
  5. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
  6. Simsonic
    I saw that thread but was hoping there were better solutions than taking out the mechanical key from the fob and taking it with me any tying it to my wetsuit.
    Is there a way to use a key code or some thing that I could hide around the vehicle?
  7. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    1. Remove the hard key from the FOB and put it on a string around your neck with your shark tooth. The sharks tooth is a good reminder that you're not surfing alone.
    2. Wrap the FOB in foil and hide it in the car.
    3. Use the hard key to lock and unlock the car door.
    4. Avoid all shark teeth except the one on the string around your neck.
    Happy Surfing :)
    ftl and xliderider like this.
  8. Simsonic
    Awesome. Thanks! Wish there was a better solution than foil, but I guess that have to do.
  9. mad-dog-one
    1,181
    421
    Whereabouts Unknown
    I use an anti-radiation cell phone bag. You can find'em on eBay for $4 to $6 shipped.
  10. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    Take the battery out of your second keyfob. Use the mechanical key to lock/unlock the door, and hold the batteryless keyfob up to the Power button to start the car.
    The batteryless keyfob can be stored in the car without wrapping it in foil.
    If somebody gets past the door lock and finds the keyfob, they'll probably still be stumped by the requirement to hold the batteryless keyfob up to the Power button.
  11. Simsonic
    These are all good solutions. I wish there was a better entry method than using the mechanical key...like some sort of keypad or locking mechanism outside the vehicle...but I guess that's an impossibility.
