For Sale: Enginer 4KW system
Discussion in 'Private Sales' started by fresno.prius, Jan 2, 2013.
  1. fresno.prius
    fresno.prius Junior Member
    fresno
    Hi! I am selling a slightly used Enginer 4KW plug-in hybrid system . I bought the kit about 1 1/2 years ago and installed it on my 2004 Toyota Prius, used it for several months, but then removed it because I did not have a commute where it would be most useful. It's been sitting for a while in my garage and now I would like to sell it. The battery management system caused me some issues and may need to be replaced after some time for greatest efficiency (about $300?), but the batteries and DC/DC inverter are virtually new. Please email me at ken dot friesen at sbcglobal dot net or call me at 559-800- four three five zero for more information. I live in Fresno but still have the shipping boxes for delivery (about $200). Thanks!
    Ken
    51,280
    welcome to p/c!
  3. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    Which batteries does your kit use? MottoCell or RealForce??
  4. fresno.prius
    fresno
    Sorry for not including those details. It uses the RealForce batteries. The BMS is 3.3.
    [email protected] likes this.
  5. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    Has this sold yet? The RFE HV battery packs what are the spec? Is this Enginer V6
  6. fresno.prius
    fresno
    I think it is version 5 but I am not positive - is there a designation on the battery or kit?
  7. banshee08
    banshee08 Member
    284
    72
    El Monte, CA USA
    If no one is interested in the kit. I would be interested int he Converter and the Charger.
  8. NortTexSalv04Prius
    915
    115
    In order for me personally to be in a mindset to BUY.. I need to know what you have.! Enginer is no longer being sold on EBAY or via there old,dated, defunct website. If you have images of the kit would be helpful. My avatar is a enginer BMS for a 4kw side view
  9. NortTexSalv04Prius
    915
    115
    I will double down on this too however would prefer images or better yet just list on ebay with images
  10. fresno.prius
    fresno
    I'd really rather sell the whole thing as a unit. Thanks for asking!
  11. NortTexSalv04Prius
    915
    115
    Any chance you can post some images like in photo bucket or sometin otherwise have no clue what you are really offerin anyway.Are you overlookin the past posts
  12. fresno.prius
    fresno
    Let's try this link.
    Enginer 4KW -Google+
    I didn't include in the pics, but also included is the BMS readout installed on the dash and also the on/off switch + cabling.
  13. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    what kinda price are you wanting for it then?
  14. fresno.prius
    fresno
    I am asking $2200. I might be willing to go down if I have no other offers, but I'm also not in a hurry to sell it so I'll see how things go.
  15. NortTexSalv04Prius
    915
    115
    So the one you are SELLING has a battery box
  16. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    So it is a version 5 kit. Being a year and a half old well before the version 6 came out. The hot weather in a Texas summer will probably cause thermal shutdowns of the version 5 converter whereas the version 6 has improved cooling efficiency and will probably not shutdown.
    It may be a better idea to buy a Version 6 DC Converter from Sushp.
    NortTexSalv04Prius likes this.
  17. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Hi lopezjm2001,
    I am in the UK across the pond, and we dont see the temperaures that you do over there (mores the pity though).
    I too have the ver 5 kit, with the realforce batteries. Is there a major difference between the converters in relation to the cooloing? I would rather mod mine if i thought cooling issues would cause failures, maybe i could mod the inverter top cover and attach a few more 48v cooling fans, what do you think i could do to improve it so to try to eliminate any future cooling problems.
    Thanks
  18. lopezjm2001
    1,146
    407
    Sydney Australia
    You are located in a cold climate. I think that in summer the temperature does not get much higher than 25deg.C. At 25deg.C you should not see any thermal shutdowns of a version 5 converter unless airflow of your converter is blocked. But in your case you should not need to add cooling devices. Most of your year is winter.
    Depending on how your kit was installed it may be possible to do something to improve airflow. The version 6 Enginer kit does not use a metal box and hence uses an open architecture so airflow is less of an issue.
  19. glyndwr
    glyndwr Member
    219
    42
    South Wales, UK
    Thanks for the reply lopez,
    where the enginer case fans exhaust air exits the case, i have left off the prius boot side plastic covers to allow the air to vent away easier in the hope that cooling is better, I do hear the converter fans come on and i have placed my hand on the converter when they fans are running to see how hot it is, but thus far doesnt get hot to touch, but i am still thinking of doing something to it as a preventative measure though.
    Thanks, Anthony
  20. fresno.prius
    fresno
    Yes, mine has a battery box (2 boxes).
