Blacking Out Bumper Grill - Vinyl or Paint?
Discussion in 'Prius c Accessories and Modifications' started by filipinoof07, Jan 3, 2013.
  1. filipinoof07
    filipinoof07 Junior Member
    66
    Just got my Silver C2. I've been looking at the pictures on mods and I really like the look of the blacked out front bumper area so many Prius C owners have done.
    A few questions:
    1. Best quality to use? (vinyl / paint /plasti dip)
    2. Easiest to install? (vinyl / paint /plasti dip)
    3. Is there a brand that is best or a specific grade I should get?
    4. Is it worth the work?
    5. Post a pic of yours, let's see how it turned out.
    Thanks
  2. Hyper_PriusC
    Hyper_PriusC Member
    83
    55
    San Jose, CA
    unless you are experienced with autobody painting, it's strongly advised to have a bodyshop do it for you for the best result.
    if you want to DIY, it's safer to do it with vinyl or plastidip. that way if you mess up, you can always peel it off and redo
    here's mine done in vinyl. if i were to re-do it again, i will use matt black instead of gloss black.
  3. filipinoof07
    66
    Looks really good! Have you worked with vinyl before? Due to the contours of the car, it seems like it would be difficult to set the boundaries of the vinyl, it's all soft curves no sharp edges.
    What's the most difficult part of this mod?
  4. Hyper_PriusC
    Hyper_PriusC Member
    83
    55
    San Jose, CA
    I have, but mostly with pre-cut vinyl graphic stickers. this would be my first time working with a large plain sheet. Other people may have different method for this. I used a paper ruler from IKEA to measure the curves, do the measurements and calculation for center points on paper, draw the shape out with a ruler on the backside of the vinyl, and then cut it out w/ a x-acto knife and ruler.
    most difficult part for me was the indentation around the license plate area. seems like that's a common issue for vinyl.
    there are probably youtube videos you can find online to do this as well. hope that helps
  5. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    I have had my bumper blacked out since a month after purchase. I had it done at the same shop that did my window tinting. I used 3M 1080 series matte black vinyl bought from Auto Vinyl Solutions
    I also have my taillights tinted using film purchased from Blinglights and again installed at tint shop
  6. filipinoof07
    66
    Your car was actually one of the first I happened to see. Your car looks real hot. Looks like they also added some material to the grill also is that an engine block for the cold? How much did the bumper blackout run you at the shop, it looks really nice?
  7. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    The tint shop charged me 200 for the front bumper and tail light tint I supplied the material.
    You can look at this post and see how I made the Grill insert for blocking
    "Grill blocking on the C | PriusChat"]Grill blocking on the C
  8. filipinoof07
    66
    Looking at vinyl, the shop is charging $30 for that, that seem worth it (those who did it themselves)?
  9. B2FiNiTY
    B2FiNiTY Active Member
    979
    227
    Seems worth it. I'm looking to do this also.
  10. Hyper_PriusC
    Hyper_PriusC Member
    83
    55
    San Jose, CA
    if they're only charging $30 then I'd say just have them do it. the material cost for me was $10 including the squeegee but I had to do it twice to get it right.
    filipinoof07 likes this.
  11. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    I had not thought about having it done by the tinting shop. Good idea. Will check with them. What about a light tint for the headlights? I am concerned about the plastic headlight cover yellowing. Maybe a light tint would stop that.
    Thanks for the idea.
    Dan
  12. B2FiNiTY
    979
    227
    I've emailed around a couple shops and they want $600-1000 dollars to wrap the front and rear bumper. That's so much!
    How much did u guys pay?!?!?
  13. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    I bought the 4 x 5 foot sheet of vinyl at AVS (Auto Vinyl Solutions) for $50 online and the place I had my windows tinted charged me $180 for the front bumper and $100 for the rear.
  14. Mendel Leisk
    41,824
    Does the vinyl stretch somewhat, around curved corners? I'm thinking of my slightly battered hatch air foil.
  15. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    Yes it will stretch if you use a heat gun to soften it.
  16. filipinoof07
    66
    Finally did it, now that it looks as if winter has passed in Indy.
    B2FiNiTY and Netineti like this.
  17. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    used 3m 1080 matte black... you guys need to really find out how much vinyl is worth..
    i was able to wrap 2 prius C's by buying $25 worth of material... with plenty of extra to spare... i'd say it was only like $10 worth of material on the car... labor? i did it myself. 1080 is really easy to work with.
  18. B2FiNiTY
    979
    227
    that looks sooooo good 007!
  19. eco31
    eco31 Member
    213
    57
    IE
    I have a front bumper garnish ordered and should be here in a month. I have a picture attached what it should look like.
  20. eco31
    eco31 Member
    213
    57
    IE
    Here is a photo of what I ordered.
