Prius C front license bracket
Discussion in 'Prius c Main Forum' started by 2buckTim, Dec 31, 2012.
  1. 2buckTim
    2buckTim New Member
    Is the Prius C supposed to come with a front license bracket?
  2. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    The Australian c has a huge one but I've not noticed one in photos of the US model.
  3. WD0AFQ
    WD0AFQ Active Member
    619
    152
    Dexter, Mo.
    Mine did.
  4. KaliforniaKid
    KaliforniaKid 2013 Prius v Five 2012 Priuc c Four
    184
    63
    Nuthern Kalifornia
    2015 Prius c
    No bracket on my C4 - just the dealer's license plate frame, two screws going into two holes in the front bumper.
  5. Phil 29 Palms CA
    119
    44
    Twentynine Palms, CA.
    I purchased my Prius C Two at the Cathedral City, CA. Toyata dealership. When I purchased my car, I demanded a Prius direct from the factory in Japan. I did not want one from another dealer or one already on the lot! I had to wait 6 weeks for my Prius to be built for me and shipped from Japan to California.
    My 2012 Prius C TWO has 2 license plate holders - one in the front and one in the rear. Two screws in each holder located at the top of the holder keep the license plate secure...
  6. koipond
    koipond Member
    198
    40
    can you show a picture of what you mean by a "holder"? is this an OEM sort of frame that goes around the license plate?
    BTW, why were you adamant about not receiving a vehicle that was already at a US dealership? Was was gained by ordering another car from Japan, where presumably the ones at the dealership had also come from?
  7. RocMills
    RocMills Active Member
    789
    277
    Las Vegas, Nevada
    My C2, purchased in Las Vegas, came with a dealership license plate frame for the back of the car only. I've not yet decided if I want to put on the front plate - mostly because I don't have the proper screws.
  8. Absolutely_Red
    56
    36
    Virginia
    2016 Prius c
    Any updates on this? My used Prius C (2016) came from a North Carolina dealer and I'm in Virginia. I need to put a Virginia license plate on the front of the car. :/
    I'm trying to figure out if I need a bracket, or if I can put a frame directly on the bumper.
  9. Mendel Leisk
    41,948
    Looking at pictures with google, looks like there's a depression on the front bumper, and an extra bracket. Check with a local dealership parts department; they should know, be able to get one in.
  10. Leadfoot J. McCoalroller
    8,152
    7,655
    Pennsylvania
    2018 Prius c
    Ours came with a bracket, obviously form-fitted to the curve of the prius bumper.
    Unfortunately they had to cut holes in the bumper to attach the bracket. Not simple drillings- these are specially shaped holes. So even though we have no need for front plates in PA, I'm stuck with a bracket out there in the wind. I wish I could find a delete plate to put in place of the bracket.
    I'm sure you could hang a plate without a bracket, but it would be better with.
  11. Absolutely_Red
    56
    36
    Virginia
    2016 Prius c
  12. Brandon Most
    Brandon Most Member
    116
    70
    Dixon, CA
    2016 Prius c
    Same way mine was done as well, I don't think there was supposed to be an additional bracket involved.
  13. djdawn
    djdawn Active Member
    256
    116
    Escondido, CA
    2014 Prius c
    My '14 model came with the dealer lic plate frame already screwed in, I didn't think anything of it. However in CA it's required to have a front lic plate. I eventually replaced that front part of my car with the garnish that has a bolt on area for Japanese lic plates:
  14. PCSpaceShip
    PCSpaceShip Member
    32
    29
    Kissimmee Florida
    2018 Prius c
    I don't need a front plate. But how bad will it look with the holes? 20180825_123802.jpeg
  15. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Did you buy the car in Florida ?
    I'm surprised that the front bracket was mounted......or installed even.
    I don't think either of mine did.
    Unscrew the two screws and see how it looks.
    Then if that bothers you, you can paint the heads of the mounting screws white and put them back in without the bracket.
  16. PCSpaceShip
    PCSpaceShip Member
    32
    29
    Kissimmee Florida
    2018 Prius c
    Yes I got it with 15miles on it in central Florida. I'll post pics of holes when I get a chance.
  17. Mendel Leisk
    41,948
    Search for "bumper plugs" too. I suppose you could just get black plugs and paint the heads with the touch-up paint (you can get from dealership). An appliance-white spray can might be close enough with your color.
  18. PCSpaceShip
    PCSpaceShip Member
    32
    29
    Kissimmee Florida
    2018 Prius c
    It turns out the screws are already painted white. However the bumper seems to have multiple openings under the plate holder which is attached to the big plastic piece. It's all one piece maybe!? I put the screws back in and casually walked away. 20180921_165226.jpeg 20180921_165232.jpeg
  19. Mendel Leisk
    41,948
    Right there:
    Ah man...
    Maybe there's some sort of heavy plastic white stickers available?
  20. PCSpaceShip
    PCSpaceShip Member
    32
    29
    Kissimmee Florida
    2018 Prius c
    There are oval triangular cut spaces to the left of the screw also. Looks like swiss cheese under there.
