Best sub location?
Discussion in 'Prius c Audio and Electronics' started by Hemy03, Dec 10, 2012.
  1. Tire well
    57.1%
  2. Rear hatch quarter panel
    28.6%
  3. Somewhere else? Suggest one and i'll look into the possibility.
    14.3%
Multiple votes are allowed.
  1. koipond
    koipond Member
    198
    40
    How's it sound??? Are you powering the new speakers from the stock amp right now (wondering how that would sound on its own) or have you put in the outboard amp? thanks!
  2. Hemy03
    Hemy03 The Flea. Work in progress.
    28
    I used a 4 channel line level
  3. Hemy03
    28
    Soun
    sound is amazing. good solid bass, excellent clarity and for the bass heads out there it would be easy to turn the gain up and play find the rattle. Right now im using the HU power to break in the speakers but have the 4 channel amp already wired up. Ill let you know the difference in sound when i cross over. but just as is, its pretty good, no distortion and balanced sound. For a stock 20 wattt max HU im impressed. considering my speakers are 75w RMS or 225 peak, that less than 20w sounds good.
  4. taco4267
    taco4267 Junior Member
    North Carolina, USA
    Thank you, lets see how mine will turn out :)
  5. Justin Park
    Justin Park Junior Member
    61
    Fullerton, California
    I hate when an interesting thread just stops and becomes deserted :[
  6. HotDogWater
    HotDogWater Junior Member
    70
    17
    Under the passenger seat!
  7. Jason Lee
    Jason Lee New Member
    2014 Prius c
    I have been looking into this as well. Heres my thought. I like the idea of cutting out the foam boards. If you were to cut out a rectangle smack dab in the middle (towards the thicker part), I think you would be able to fit one of these:
    Alpine SBR-S83V Ported enclosure with one 8" Type-R subwoofer at Crutchfield.com
    It may (may not) stick up above the surface around an inch or two, but I think it would look clean and save the minimal trunk space we have. Thoughts??
  8. Jt Torres
    Jt Torres Junior Member
    HB CA
    image.jpg I'm thinking about building something cool for my Prius C.
    #28 Jt Torres, Jun 15, 2014
