new steering wheel for my Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by madmarc, Nov 18, 2012.
  1. madmarc
    madmarc Junior Member
    Graz / Austria
    Here the first pictures of my new steering wheel for my prius:
  2. Justdidit
    Justdidit LVNPZEV
    1,880
    709
    75
    Carrollton, Texas
    Four Touring
    Nice! Was the install difficult?
  3. madmarc
    Graz / Austria
    no wasn't. You need some tools (Torx27 and 19mm wrench) and disconnect the 12V battery for disconnecting the airbag.
    You need about 5 minutes for installing the new steering wheel.
  4. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
    Wow! It looks great! Can you tell us more about where you bought it and how you installed it. My steering wheel is looking worn out and I'd rather not put a cover over it, I want a replacement! What you've done is exactly what I was looking for :)
  5. madmarc
    Graz / Austria
    I sell these steering wheels.
    Send me PM, I can send you details.
  6. BlackOps_Noob
    BlackOps_Noob Junior Member
    32
    Would it be the same for a 2011?
  7. madmarc
    Graz / Austria
    yes for prius 3 we also have steering wheels. In about 14 days the first delivery will arrive.
  8. madmarc
    Graz / Austria
    Here some pictures of other Steering wheels:
    NEU PRIUS 3 alle Modelle
    Daves09prius likes this.
  9. koipond
    koipond Member
    198
    39
    wow. stunning. the most beautiful/tasteful yet comfortable-looking steering wheel for the Prius yet. the version for the Prius 3 (like that of the Prius C) designed for the two silver overlapping lower spokes... is is possible to get a version with the top and bottom non-perforated sections in a color other than black... maybe a blue? Resulting in a two-tone leather (black perforated and blue solid areas)?
  10. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    Does this include the 15 minute wait after disconnecting the battery to ensure the airbag does not accidentally deploy? ;)
    What about the use of a steering wheel puller? I've yet to meet a wheel that's slid off easily...
  11. Daves09prius
    680
    161
    Gettysburg, PA
    Removal of 2008 Prius steering wheel - - FixYa
    I would disconnect the negative wire from the battery prior to doing this...
    With a small flat screwdriver, remove the 2 by 2 inch black plastic covers behind the steering wheel. one of them has a hole for the cruis control lever.
    loosen but dont remove the two torx screws behind these covers.
    allow the airbag to fall out into your hands.
    carefully raise the two yellow retainers on the airbag wires, then pull the wires away from the airbag module.
    then squeeze and pull the black horn wire from the airbag.
    to replace the steering wheel, unplug all the wires you see and remove the 19mm nut holding the wheel.
    then by hand wiggle the steering wheel toward you.
  12. madmarc
    Graz / Austria
    yes alot of colours are aviable. But I only have these in stock.
    Other colors where manufactured when you order it.
  13. koipond
    koipond Member
    198
    39
    Fantastic. What's an (even approximate) price? How would I go about ordering and selecting color options (like the same dark black/grey with blue thread, but having the solid center piece solid blue)?
    Thanks!
  14. art1981
    art1981 Junior Member
    where I can buy it ?)))
  15. Daves09prius
    680
    161
    Gettysburg, PA
    PM Madmarc - He sells them
  16. sidecar
    sidecar Member
    342
    44
    Australia
    is it situated any closer to the driver?
    mine always seems a little too far away, just by an inch or so
  17. cozmisu
    cozmisu Junior Member
    24
    Romania
    How much is a steering wheel ?
  18. art1981
    Hello madmarc !) need this steering wheel. With grey stitches building nice II GEN Prius. Got everything fresh but steering wheel is my #1 in the priorities left. Will buy it from you.
    Tell me where how and how much?) feel very comfortable with ebay.But there only JDM and only for III GEN Priuses.
    Pls send me the quote to ubitamolodost@ gmail or send me to your online store if you have it. Would appreciate you sending me a cover without the frame if it easier for you . Waiting for your respond.
  19. Stricklinator
    Stricklinator New Member
    Also interested in a steering wheel for my 2009 Prius.
  20. charlesdc54
    charlesdc54 Junior Member
    35
    corona ca
    Dose the air bag have to be reset when changing the steering wheel?
