Samsung Galaxy Note 2...can't stream music?
Discussion in 'Gen 3 Prius Audio and Electronics' started by manku, Dec 26, 2012.
  1. manku
    manku Junior Member
    29
    United States
    I have a 2011 Prius 3 w/NAV...my last two phones (HTC Sensation/HTC One S) have been able to stream music via Bluetooth, though the HTC One S (ICS) seemed to have some connection issues (it would drop if I got a call sometimes, occasionally it wouldn't recognize music and I'd have to reboot phone etc...)
    I now have a Samsung Galaxy Note 2 (tmobile)...I was able to hook up the phone portion, but no audio...it is the "JellyBean" os. Any suggestions, or am I screwed?
    Thanks.
  2. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    My Galaxy S3 with Jelly Bean works with the HDD headunit. Does Pandora via Entune work? That uses the BT Audio protocol too.
  3. manku
    manku Junior Member
    29
    United States
    No...keeps saying unable to connect to bluetooth!
  4. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Try deleting all paired devices in both of the car, and the phone, reboot both, before making a final pairing. I have seen duplicated entries for the same device causing issues with BT connectivity.
  5. Ragin Cajun
    Ragin Cajun Junior Member
    52
    My Note 2 pairs fine and plays thru bluetooth with zero issues.
  6. manku
    manku Junior Member
    29
    United States
    Took to Toyota dealership...erased all connections...turns out, you have to pair audio first, then phone...otherwise all hell breaks loose.
    It's working now.
    Am I imaging things, or did my HTC One S (with Beats Audio) sound better?
    Thanks.
  7. miketee
    miketee Junior Member
    52
    Prince George's County, Maryland
    Just got a Note 2...no issues streaming music and pairing the phone but transferring contacts only produces a partial list (97 out of 128). I don't need all of them but some important ones I call frequently got left out. Anyone else have this problem? I deleted my old phone and contact list.
    Oh...I have a 2012 IV with the HD Nav system.
  8. DaWeav
    DaWeav Junior Member
    91
    Lemoore, CA
    I had the same issue with the S3. What I did was reformat all the contact phone numbers on Google using my PC to get rid of the '(', ')', and '-'. I also had one or two that I just had to delete and recreate to get them to sync.
    The problem I still have is that only a few contact pictures transfer during sync. There is just no sense why all the contact pictures don't transfer. I'm only getting four out of sixty pictures and can't seem to figure it out.
    GT-P7310 ? HD
  9. miketee
    52
    Thanks...will try going back to Google contact list and/or delete and recreate the missing ones. I don't care so much about the contact pictures although it seems everything should sync. Hopefully, Samsung and/or Toyota will fix this bug soon.
  10. miketee
    52
    Putting contacts directly into the phone then syncing seems to work...a quick solution if you only have a few.
