Car Starts But Won't Go
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by hilltopper, Jan 4, 2013.
  1. hilltopper
    hilltopper Junior Member
    About once a week our 2011 Prius will start, but the "Ready" indicator does not come on and the car cannot be shifted into drive. Once this happens it takes several attempts, turning the car on/off, until it finally comes on "Ready." I cannot create the problem, but it may stem from pushing the start button before the brake is fully depressed. Last night it took more than 5 minutes to get it going. I "reset" the car by exiting, locking, and reentering the car. Then it worked, though I have no idea if that procedure caused it to work. Dealer had no ideas when I took it in a month ago. The dealer is far away too, so looking for ideas here.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The next time this happens, see if you can see your brake light reflections when you step on the brake and before you press the Power button. If you cannot see the brake lights then you either are not pressing the brake pedal hard enough or you may have a switch that needs adjustment.
  3. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    I'm wondering if it's possible that there's something with the brake system that's not indicating that you have the brake pressed in. Which leads me to a more serious potential problem...
    Have you noticed any difference in the brake during normal operations?
    (I'm praying it's only a "during startup" thing but it's worth asking)
  4. Former Member 68813
    3,524
    983
    US
    check the 12v battery.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Yep. OP: Do you have a multimeter/volt-ohm meter w/which to check its voltage after the car has sat overnight?
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    If it is the brake switch/wiring, the Power button LED would remain red and not green. That is something to check for when it happens again. Does it enter into the ACC mode if it doesn't go to Ready?
  7. hilltopper
    Thanks for the replies. Actually, the problem has always been after the car was parked away from home, sometimes just briefly on errands- not after overnight in the garage, so I don't think its the 12v battery. Now it hasn't happened in a couple days...
  8. 808PriusGirl
    808PriusGirl New Member
    Riverside, CA
    I've been having the same problem but all the lights on the dash come on. I have to press the Power button several times before it will start. It seems to do better after I have been driving it around so I don't know if it is the 12V battery. I'm a new Prius owner so I don't know if I'm just not doing something right or if there is a problem.
  9. Samprocat
    Samprocat Active Member
    491
    297
    Lincoln, NE
    Checking battery voltage is not good practice to know health of the battery....
    He needs load test the battery
  10. Mendel Leisk
    41,638
    Still, checking the battery voltage will give you some insight.
    FWIW I've got both a multimeter and a Solar BA5 (digital load tester). The multimeter test of voltage, while not as conclusive, is still a good quick-check. To use the Solar I need to dig down to the battery (not as accesible on 3rd gen), and ensure clamps are directly on the posts.
    Raytheeagle likes this.
